Question about Canon PIXMA MP600 all-In-One InkJet Printer
Paper wheel not working
It appears that the wheel that is supposed to grab the paper is not turning.  Does anyone have a solution?  It is only about 1 and a half years old.
    Sergeant:
    Champion:
  • 237 Answers
Sounds Like the gear is not turning could be caused from a motor not turning or the gears teeth are damaged
Posted on Feb 10, 2009
Hp Officejet 6500 won't feed paper
Problem:
The 'drop down paper grabber' gears are not turning, and the printer gives you an error saying to make sure there is paper in the printer.
All of the fixes on the internet are for working printers, and their approach is to clean the rollers if they are not grabbing the paper. They are assuming they are turning properly and the rubber grabbing wheels are wither dirty of dried out.
In my case, however, the gears were not turning, and so the rubber grabbers wheels were not turning, even though the whole 'paper grabber' unit was dropping down properly
Solution:
Just inside the paper loader tray, along the top, there is a metal rod. It is about 1 inch from the front.
The gears from the drop down paper grabber are supposed to meet a gear that resides on this rod and sort of floats on it. However, the gear on my printer slipped to the left, and was not making contact with the other gears.
You can gently put your finger on the gears as you do a copy command, and confirm this.
To fix the printer, I just slid the floating gear over to the right and into place, and the paper began feeding properly.
Why there is nothing to keep the gear in place is a mystery to me.
Aug 20, 2014 | HP Officejet 6500 Wireless All-in-One...
Automatic feed does not work
The wheels that are supposed to grab the paper might be dirty or broken, the reason can also be that the sensor that should see the paper doesnt work for some reason.
Nov 14, 2011 | Xerox WorkCentre XL2130f Laser Printer
My printer X3350 has trouble grabbing the paper from the paper tray. What can is the problem. I tried cleaning the grabber wheel. But it still won't grab the paper.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 21, 2011 | Lexmark X3350 All-In-One InkJet Printer
The paper always jams when I want to print. It grabs the right side of the paper and scrunches the left side. It is a lexmark x5150 I have tried different paper and nothing works.
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 06, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printer does not "grab" paper but can see parts turning
you have bad rollers. you can try to clean the roller with an alchohol wipe but I doubt it will help much. You need to have the roller replaced or get a new printer
May 27, 2009 | Dell 922 All-In-One InkJet Printer
Paper Not Fed From Tray 2
you have to open the printer to get to the lower part of it which hides the 2nd paper tray and gear/wheel drive.
check the wheel and gears of the 2nd paper feeder.
I guess you have to click the gear back into position.
May 05, 2008 | Brother MFC-5860CN InkJet Printer
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
