Hey, you may want to remove the upper handle to see if the wire harness is protruding, then reinstall making sure the handle is fully inserted onto the machine.
If you continue to experience no power, you may want to have one of BISSELL's Authorized Service Centers inspect your machine.
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Not enough info to help fully. I'd call Bissell Consumer Care at 1-800-237-7691 Remember, you don't have the knowledge of seeing the inside before but they should have a troubleshooting guide to walk you thru it. Good Luck. Hope that Helped.
You may want to have your vacuum inspected by a Qualified Technician at one of BISSELL's Authorized Service Centers. Here's a quick link to ssist you in locating one. http://www.bissell.com/service-centers/?cid=ccsocial
