Question about Craig 731398407019 Portable DVD Player
A/V Cables Needed
We have lost our A/V cable to hook our portable into the home TV, can you tell me where I can purchase a new cable. Local stores don't have them. Thanks
  • 3 Answers
Try ebay , or amazon or even radio shacks websites .
Posted on Feb 09, 2009
I have bought a Sony BDP-S380 Blu-Ray Disc Player. I have read the scanty instructions for hooking it up to my home entertainment system but still am unclear how to do it, which connection jacks to use...
Without knowing what your Home Entertainment System or TV capabilities are...
Page 10 of the not-so-scanty instructions lists the various video hook-ups to your TV in descending order or quality...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=BDPS380&LOC=3
Here's how I would do it.
HDMI from the BD to the TV.
Digital audio (standard RCA cable) from the BD to the 'system'.
The best video goes to the TV without hops and extra expensive cable. The best audio goes to the sound system on the cheapest cable which can also be spliced for added length.
I never run either audio or video anywhere it isn't needed or enhanced.
Mar 20, 2011 | Audio Players & Recorders
Where can I purchase the cable to connect my dvd player to my tv..I need the one that has a pin on one end and a white/yellow on the other
Hello hyegee -- You could probably get one directly from the manufacturer at a way over the top price. The cheapest and easiest thing to do is to get two generic cables at any store that carries electronic accessories.
For audio you need a stereo 3.5 mm male to stereo RCA jacks male cable. For video you need a simple 3.5 mm video male to RCA jack male video.
Here is the graphic from the user manual. Yours new cables would hook up the same but just be two instead of one cable:
Good Luck and thanks for using Fix Ya
Mikeywaf
Mar 20, 2011 | Coby TF-DVD7307 Portable DVD Player
Purchased the LHB335 Network blue ray disc home theater system. Hooked it up with an HDMI cable. We can only get the surround sound to work thru the DVD player. We either don't know what in put to have the...
If you can take very close up pics of the back of the blu ray, and the connection site on the tv and foward to my email I can tell you exactly how everything should be hooked uo, marpltvt86@aol.com. Usually its just a simle issue of relocating a wire or 2
Mar 06, 2011 | LG LHB335 Theater System
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
How do I hook up my PS3 to my 65" Mitsubishi Home Theater Television? What all cables do I need? I've tries to hook it up like I had it on my other Home Theater TV and it does not work! Is it b/c of...
Tries hook it up with a cable that call the HDMI cable.Tries websites like Amazon.com,Ebay.com to buy one.One side of the HDMI cable the OUT put PS3 hub the other side of the HDMI cable to the tv HDMI plug in the tv side IN hub.
Dec 11, 2010 | Televison & Video
I just made a big mistake purchasing a 13'' Sharp Linytron at a garage sale. I just needed a small tv for my office that can connect to cable. Well,from the comments I have read. There seems to be no...
you need to get an adapter for the cable hook up. you probably have screws on the back for an regular antenna. you can buy an adapter at radio shack or one of your electronic stores. this would have an cable connection on one end and 2 u's on the other to screw into the back of your tv. you just need an adapter. or you can find 10' portable tv's and lower at www.radioshack.com that would work with cable.
Feb 22, 2010 | Televison & Video
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Sony c450 will not work with new 46" Samsung TV using compodent 3
are you sure that the channel your tv is on matches the name on the inputs where you plugged the component cables in? Channel surf-maybe start at 2 and go down and that is where those input channels should be.
Sep 01, 2009 | Sony DAV-C450 System
Need cables from dvd portable MTP-Player to watch movis on my TV
These cables are easily purchased from any large electrical store.
Aug 19, 2009 | Mintek MDP-1030 Portable DVD Player
Craig 731398407019 Portable DVD Player Logo
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
