Question about Sony SDM-S95AR (Black) 19" Monitor
I have a Sony SDM S95Ar monitor - Power light flashes but monitor
Not much more to say really - The monitor is clearly receiving power as the power light is flashing but it will not turn on.
  • 102 Answers
Ur getting power but maybe no video check your card
Posted on Feb 09, 2009
Monitor light up then shut down itself
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
Power
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
Sony sdm hs75p doesn't power on
try replacing the back light inside the monitor.
Aug 15, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
SDM-HS73P Screen Flashes
This is a problem I have seen with a few LG monitors.
Your Inverter circuit is fine (that powers the lights to your screen so you can see the image on the LCD panel) but the monitor does not like having a video signal attached to it.
  1. Bad capacitors on the power board can upset the current going to the controller board. This board included the video input circuit and the power supply needs to be stable for this to operate.
  2. The controller IC that translates the video signal into what the LCD panel controller can understand is failing. Normally this fault occurs in the horizontal and vertical input of the IC. The fact you can see the other message on screen is due to it going through it's own internal and seperate section of the IC. In this case the only repair option is to replace the internal video board. Sony will not supply the parts directly to the public, but if you are really nice, they "may" tell you where to get one externally to Sony.
Hope that helps =)
Apr 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Lost power supply
Yes, lcdpayless.com has this kind special power adapter. You can just search it by model# SDM-M81 at the homepage.
or just click as below link and check it out.
http://lcdpayless.com/productpage.php?productId=4125
Apr 10, 2008 | Sony SDM M81 18.1" LCD Monitor
Sony SDM HS75 Monitor
it is logic board problume nothing else
Jan 08, 2008 | Sony SDM-HS75 17" LCD Monitor
SDM-HS73P Sony monitor
buddy just check the power cable of the monitor... may be there is problem with the power cable try changing power cable...
and also after connecting with the old cable only just press the power button of the monitor may be it s turned off... try turning it on...
Aug 16, 2006 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-S95AR (Black) 19" Monitor Logo
145 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
