Question about HP Pavilion tx2500z Notebook
HP Pavilion laptop went black as I was surfing
It won't turn back on. Battery, power cord fine. Held power button for 6+ seconds but won't turn back on.
  • 1 more comment
  • mlm1065 Feb 09, 2009
    Clarifying... yes she gets the blue light on so power is getting to computer
    Thanks to both who have submitted. The computer is with my daughter in Italy!! She is as non-tech as you can get. So I doubt she will try reseating the memory card. We will try the tapping and see if she can find a tech person there. I will get back to you on this and thanks
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you getting any kind of lights at all, or is the laptop totally dead
  • HP Master
  • 2,404 Answers
Okay if you have lights then I would suggest with the laptop turned off, try reseating the memory then only hook up the AC adaptor with the battery out and see if you get video. If that doesn't work then try putting the memory into another slot and trying the process again. Also make sure there is no dust or dirt on the memory or in the slots. A quick blow of a can of air softly can do the trick to make sure things are clean on the memory and the slots.
If after this you still have no video and the hard drive light is not flickering like its trying to load windows then your motherboard is bad.
Posted on Feb 09, 2009
  • 479 Answers
If after refixing the battery also the issue is not resolved so try to tap num lock when restarting the machine.
if no power is there issue might be related to motherboard.
if taping the num lock glows the lED of numlock means RAm is faulty.
Laptop will not power on
Unfortunatelly it's the mainboard.
Dec 17, 2012 | HP Pavilion 2500 Notebook
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
WAS WORKING FINE FOR 2 YEARS. ALL OF THE SUDDEN I GET THE BLACK SCREEN. I WAS ABLE TO GET IT BACK ON AND DID A COMPLETE RECOVERY. IT STAYED ON FOR ABOUT20 MINUTES AND THEN AN ERROR MESSAGE ''DISPLAY...
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
hat will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!.
Mar 02, 2010 | Computers & Internet
Hp pavilion dv6775us will not power up.
These are the reasons why your pc wont switch on
1. Defective power adapter
2. Defective Processor
3. Defective Motherboard
Note: If you replaced your motherboard check the specs on the previous motherboard it should be the same part number or a replacement part number.
You can purchase your motherboard to HP System Board HP Motherboard
Here's a sample video
Feb 13, 2010 | HP Pavilion dv6775us Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion tx2500z Notebook Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
