It heats and it tumbles but clothes aren't dry. we replaced the internal bias thermostat, the thermal fuse and the high heat thermostat and still won't work. also replaced the vent pipe. help!
SOURCE: Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
SOURCE: I have a magtag gas dryer with that heat sensor
Hi Joy Ann,
The automatic cycle of your dryer depends on air circulating in, through and out of your dryer efficiently. If air isn't circulating properly, your timer will stall and run forever.
Timed Dry, on the other hand is independent. The timer only does what it's told to do... count down time.
So, yes. You do have a blockage in the vent to outside. When you said the "Vents are clean", I presume you mean the lint filter. That's good. It's always good to keep that clear. What I'm talking about is the four inch vent tube from the dryer to the wall. How close is the back of the dryer to the wall? If it's less than 4", the vent is crushed. Take a flashlight and look behind the dryer without moving it. See that flex hose back there connecting the dryer to the wall? If it is pinched, so is your air flow. Either pull the dryer out about 8" from the wall, or shorten the hose.
If all of that checks out OK, though.. (your flex line to the wall isn't pinched) that means that the vent in the wall is blocked somewhere. Trust me... I've seen all kinds of things block vents to the outside. Bird nests mainly, squirrel's, reptiles, rodents... they all love to build nests in the warm place <--that would be your dryer exhaust.
Recommendation: pull the dryer out at LEAST 8" from the wall and see if that helps. If not, your Home's internal dryer vent should be professionally cleaned (should be done once a year for 2 story Homes).
Bottom line is this... if your dryer is heating, it's trying to do its' job. The only reason it can't is because air isn't circulating properly.
Look into it, Joy Ann... Dryer fires are serious and they are caused by blocked ventilation.
Hope this helps,
SG
SOURCE: my kenmore 70 series dryer
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
SOURCE: Kenmore 80 Series Heavy Duty Electrc Dryer runs but will not heat
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
