Question about Whirlpool LER5636P Electric Dryer
Whirlpool Electric: Light is on, but no turn or no heat
Whirlpool electric dryer has the light continuously on inside even when the door is closed, but it doesn't turn or blow air or heat.
  • 257 Answers
Hi, Good troubleshooting! If the light stays on and nothing works it indicates the door switch is the problem. Best of Luck to you! Please rate my response.
Posted on Feb 09, 2009
If the dryer inside light comes on can the thermal fuse ok
No relations at all......
Light comes on means there is power and your door is open.
Thermal fuse failure means there is no heat. No current going through your heating circuit. Most models and brands will still turn the drum without heat. But there are some models thermal fuse will completely shut the power to heating circuit and drum motor. Like KENMORE certain dryers made by Whirlpool corporation
Jul 22, 2014 | GE GTDP180EDWW Electric Dryers
Why won't my Whirlpool Senseon Dryer start? The control panel will not respond. No buttoms will light up or beep. The dryer has power and the door latch works properly and the light comes on inside
Always disconnect power before attempting any service. Most electric dryers require 240 volts to operate properly.
You may have only 120 volts to supply the dryer which will give you your symptoms. Click dryer circuit breaker off then back on to reset 240 volt system.Still no heat/run
This link will aid you in tear down / diagnostics/parts
Nov 21, 2017 | Whirlpool Dryers
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 21, 2011 | Whirlpool Dryers
Dryer is turning, no heat is coming out, timer is not working
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Nov 05, 2009 | Whirlpool GEW9250 Electric Dryer
Not getting power
Sounds like maybe a door switch, thermostat or the thermal fuse. You can check for continuity across the terminals with dryer unplugged. Usually the thermal fuse and thermostats are located by the heating element
Apr 04, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
first, check if the start switch is making contact. that's the thing that you press. you can use any continuity tester to test it. test also the door switch. it may be broke. both should have continuity when you press the switch and when you closes the door.
Feb 11, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
