Question about Canon Pixma iP6600D InkJet Photo Printer
Grey sponge came out when I pulled a jammed paper out of printer
A long narrow grey sponge came out of the front paper feed pixma 6600 when I removed a stuck paper/
  • Anonymous Feb 09, 2009
    When I pulled out a paper that got stuck at the front of the Canon Printer Pixma ip6600D, a long grey sponge came out and are hanging out infront of the printer
  • veradt Feb 09, 2009
    Thank you, but the sponge is hanging halfway out, so how do I put it back? It will tear if I pull it out because it is stuck, and I do not know where it belongs.
    Problem Solver:
  • 11 Answers
Its the ink blotter it collects any excess ink when you load in new ink cartridges you can still use it but watch out for any spills ...
hope this helps... jedi-inc...
Posted on Feb 09, 2009
  • jedi inc
    jedi inc Feb 09, 2009
    if you take it apart be carefull as you may do more damage but it should go under the ink return ( where the print head returns to ) or under the paper out slot ...or at the back of the printer under the paper in slot ...it is in a diferent place for each printer but the basics of a printer are the same...
    what colour is the sponge and how old is your printer as most carry a 1 year fix guarantee..just get in touch with the printer company or where you got it from ....don't make any difference if you have used it....
    if the sponge is white then it is the blotting sponge ...under print head..
    if its any other its the overspill ink sponge ....both you could work without...
    i have taken so many printers apart and its very very dirty job if you get ink on your hands ..it stains and lasts for about a week ....go carefull ....
    thats all i know ..hope this helps ...jedi-inc...
  • jedi inc
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Canon Printer Pixma MX700
user a small object.. got pins? something small to Grab the paper. Il get you the paper jam clearing instructions for your model.
Oct 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
My canon pixma MP210, is not feeding the paper through, seems to jam, but printer still is printing. The paper is taken about 10cms into printer, then twists slightly but does not fee through. Have checked...
There is a foreign object in the paper tray. Because it is curved you cannot see it. It is stuck in the narrowed area right before the feeding rollers.
Disconnect the cables and rotate the printer in a way it stands on its back.
Open the front cover. Use long thin flat screw driver that can go trough the paper out area and to reach the feed roller.Insert the screw driver between each pressure roller and the the feed roller to release the object. If successful it will fall out from the tray. Usually it's a coin, pen, point-protector, ruller, paper clip and so on.
Aug 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
A piece of foam sponge under the ink catridges has broken, and the printer will not cleanly draw paper for printing - it jams.
The sponge under the print cartridges is to soak up the ink when cleaning the print heads. If part of it broken off and lodged in the rollers where the paper is drawn into the printer then try to locate the sponge and remove it. Sounds like it's lodged somewhere and jamming the paper feed.
May 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper will not feed inti printer
The sensor that detects paper (most cases just a small lever that is pushed up by paper in the tray) isn't engaging. It could be that the paper is not fully inserted, or sometimes in a paper jam, people pull the jammed page out backwards, bending or dislodging the lever. Very common in back-fed printers and shredders.
Sometimes just a visual inspection with a bright light source can show the problem. Be careful not to turn the printer on its side or upside down for any length of time. Inkjet printers usually use a sponge for excess ink discharged during the cleaning process and that can run out and seriously gum up the works, electronics, carpet, and whatever else you really don't want it to.
Aug 24, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam
I had this problem the other day. I turned out that I had a small bit of polystyrene foam had got trapped just before the white plastic rollers you can see in front of the toner sponge where the cartridge head runs when you lift the lid to change ink.
I discovered it by noting that on power-up these rollers turn as if to feed paper back into the paper feeder (i.e. "backwards through the printer"), so I tried to see if I could get a sheet to feed backwards and noticed something was trying to stop the right-hand side of the paper feeding in. Soon after I noticed the bit of foam through the right-hand side slot in the white plastic section above the roller. A quick removal with small tweezers et viola!
Andy
Feb 10, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Canon Pixma iP6600D InkJet Photo Printer Logo
95 people viewed this question
old marine
old marine
