Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Verbatim USB HD, 1TB is not recognized at all.
The green light on the front panel is on, but that is all there is.
i just hope that the hard disk itself is still alive so as to buy another box..
if there is/are tools or other suggestions on how get it going again i'd more than grateful to you.
thanks.
  • 1 more comment
  • Anonymous Feb 09, 2009
    I have the exact same problem. It's a band new and Windows can't seem to see it, it reports "Unknown Device"
  • elkwithabow Feb 11, 2009
    Same problem.  It worked fine for 2 months then just disappeared from my computer.  Shows as an unknown usb device but can't access.
  • blixt Feb 23, 2009
    I have the same problem: It worked fine for 2 months then just disappeared from my computer. Shows as an unknown usb device but can't access. I have also test it on another PC with same result, but if I connect it to PS3 then I can use all info on the disk?
    (Verbatim 1TB 3,5")
SOURCE: Verbatim Store n go 4 GB USB HD Drive
Wicked. Thanks. (:
Posted on Sep 18, 2008
Crankstart
  • 696 Answers
SOURCE: WD 1TB USB 2.0 EXT HD - NOT RECOGNIZED
Hi First things first, is the light on the front still coming on? If not try a new power supply or moving the drive to a new shell as the problem is either in the AC adapter or in the shell.
If the light is on it only confirms that you have power, but first try a different set of USB ports and if that doesn't work try a different computer. If it works on the other ports, no biggy, use it there. If it doesn't and works on a different computer then it's likely your registry entry for the device is damaged, get back to me if that is the case. If it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried these suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
  • 13 Answers
SOURCE: 1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Posted on Aug 08, 2009
YourZEN
  • 820 Answers
SOURCE: WinXP does not recognize USB device for Verbatim
Troubleshooting your USB hard drive in Windows see:
http://www.verbatim.com/support/support-article.cfm?support_id=7B8B6B2C-1422-1392-A8B4CF52416BBF75&supportType=Article
  • First check:
Link to determine the hard drive getting enough power:
http://www.verbatim.com/support/support-article.cfm?support_id=7B4B78B1-1422-1392-A837F379D15C6F2E&supportType=Article
  • Next check the hardware in My Computer > Device Manager if there are "yellow marks" for devices that require driver software to be installed.
When devices e.g. printer is connected before you installed the needed software, it can happen that the USB port is no longer recognized.
Then remove the device that shows having problems in the hardware manager.
Next install the software.
Connect afterwards or at the time the computer asks to do so.
Link to your external hard drive USB 500GB on the internet:
http://www.verbatim.com/products/detail.cfm?product_id=A2EDE0FA-1143-3415-5F5A5A7E80921FE8&cat_id=A2EEE0D6-1143-3415-5FC347F5645B6AE1
Posted on Sep 24, 2009
fish8037
  • 121 Answers
SOURCE: My computer will not recognize the external HD. I
Not sure how new your computer is but on some older ones there is not enough power from just one USB port to power the drive correctly. If your drive spins up (sounds like it is revving up) then you should be getting enough power but if not then you will need to purchase a Y USB cable to properly power the drive.
Posted on Jul 25, 2010
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
Am having problem my Verbatim Usb 1 tb is not recognising in any port of my PC
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or:
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 13, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
My wd hard disk(1TB My Book) is not detected on my pc or laptop, earlier all the three lights in the front pannel used to glow but now only the power supply light glows ....
click start control panel administrive tools ,computer management :device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers: or
hope this helps
Jul 05, 2011 | Western Digital My Book Essential 1TB...
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Jun 09, 2011 | Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive
Using Windows 7. 1TB My Passport WD external HD. It shows in Windows as healthy RAW but won't take a format. I tried writing all zeros with Acronis but it failed. Tried DataLifeguard. failed. I'm out...
just a few ideas
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
click start control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Apr 23, 2011 | Western Digital 1TB My Passport Essential...
My notebook is not detecting this desktop drive (3.5'' 1 TB external desktop hard drive - verbatim). My other 500 GB external hard drives are properly detected.
Go to Control Panel - Administrative Tools - Computer Management Then go into Disk Management. Hopefully you will see a drive with a capacity of about 480 GB (plus or minus), that's your disk.
Right click on it and select change drive letter and change the drive letter to something that isn't in use.
If that doesn't work or it doesn't show up, go into the Device Manager from the Computer Management screen and see if there is anything under disk drives with a yellow or red symbol next to it. If so, right click it, select uninstall, then unplug the disk drive and plug it back in.
Feb 27, 2011 | Verbatim 1TB SMARTDISK HD USB-FWIRE COMBO...
I have the same problem with my Verbatim media station 1Tb. It starts up but goes no further. The verbatim logo is on the screen but disappears and reappears after a short while. The remote control does...
> what is a PSU ?
Either Pennsylvania State University of Power Supply Unit.
> problem with my Verbatim ...
Is it still under warranty?
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If it still is not detected, then either exercise the warranty,
or disassemble the case, to find two major parts:
* a disk-drive
* a USB-to-disk-drive adapter
Disconnect the disk-drive and connect it as a "slave" disk-drive in some desktop computer, to see if it is recognized, i.e., if it was the USB-to-disk-drive adapter that has failed.
If it still is not recognized, then it is "dead". You could buy a similar disk-drive, install it into the enclosure, and thus create another external storage device.
Oct 13, 2010 | Computers & Internet
Verbatim hard drive wont turn on
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
Oct 07, 2009 | Verbatim VER95327 USB Hard Drive
Trying to use a brand new Verbatim usb 500GB portable hard drive
For WindowsXP:
Goto Start> Control Panel>
Select Hardware Tab > Divice Manager
Select the + on Disk drives, and see if you see your USB Verbatim drive listed (if so good, close all thoes windows and goto the next steps) If not stop here.
From the Contorl Panel> Administratinve Tools> Computer mangement>
Under Stoage select Disk Management on the left panel
Look in the Right panel and single click your USB drive in the "Volume" colume.
Know look at the lower panel and make sure the drive states that it is "Online", look at the "Health" Status. And;
Make sure it has been "Partitioned" in the Layout colume. If not right mouse click the drive letter and select "Mark Potiton as Active".
Right mouse click on the USB drive in the Volume colume> select "Change Drive Letter and Paths"
If there is on drive letter assing to it select the Add button, if one is there, select the Change button and assign one to it or change it to a drive letter that is beyound the number of drives you have.
In other works if you have drives C:, D: and E: before you add the USB drive, make it the H: drive.
Exit out.
Now check your drive files.
Jan 21, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
455 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
