Question about Sun netra Computers & Internet
Netra t1400 can't power on
Here is my problems and hope some one on the list can help out.
I hook up hyper terminal via cisco cable to Alarm port.
I can see lom> prompt, but can not boot up the system.
I can run, show, reset, poweroff and poweron and then it show lom> again, but can't pass this.
Here is the infofrom the lom> command:
model Netra t140x
hostname cl107
PSU 3 InB failed
PSU 3 Input failed
PSU 2 Input failed
PSU 1 Input failed
PSU 1 InB failed
PSU 2 Input failed
PSU 3 Input failed
PSU 2 InB failed
PSU 3 InB failed
power on
first fatal error ( I open the box and see the FAN 1 is running fine.)
Fan 1 failed
Fault OFF
Alarm1 OFF
Alarm2 OFF
Alarm3 ON
1 OK speed 50%
2 OK speed 60%
3 OK speed 58%
4 OK speed 58%
1 InB failed
2 InB failed
3 InB failed
This Netra has DC power with A and B. A power is on, B if off. I even plug in both A and B. Still can't pass LOM.
Thus I need your help.
2 Suggested Answers
  • 19396 Answers
SOURCE: Samsug HT-SK5 fails with 'Protection' on display
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Posted on May 04, 2009
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
What is the default ip address for powerconnect 5212
By default there isn't one you need to use the serial cable and hook it up the console port and log into it with a terminal program such as hyper terminal or putty
Nov 26, 2012 | Dell PowerConnect 5212 (p5223np)
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
Im need to cisco cable 72-3383-01 free driver for win 2000
You don't need a driver. It's Hyper Terminal. So use that or Putty.
Jul 10, 2011 | Cisco Compatible DB9 to RJ45 Console...
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
May 02, 2011 | Cisco Compatible DB9 to RJ45 Console...
The console port fails to connect suddenly
are you using hyper terminal? if you are using another program, switch to hyperterminal and reboot (if possible after saving config) with the cable connected. See if anything at all comes up on the screen.
Apr 16, 2009 | Cisco ASA 5510 Firewall
Cisco catalyst 3500xl (24 port) bad console
It is possible that your console port is configured for a different baud rate. Try to change your baud rate on your hyper terminal going from 115200 down to 2400. If it doesn't work you might have a problem with 232 driver chip that is located on the board next to your console port. You will not be able to find a schematics for this switch, it is not available for the public.
You can send this switch to me. I will glad to fix it for you.
Good luck.
Jul 05, 2008 | Cisco Catalyst 2924-XL Enterprise Edition...
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
1 Answer unreachable
you can use the "ifconfig -a" to see the ip addresses of all network adapters. but i'm wondering what happened to the user interface that showed a list of options to choose from.
Mar 15, 2008 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
102 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
