Question about Sony Walkman WM-FX290 Personal Cassette Player
WALKMAN ex34 hOW DO YOU OPEN THIS
Just stopped working Replaced batteries, applied 3Vdc from adapter. Still not working
  • jeffrycalhou Mar 15, 2009
    This time it would not run, or display despite new battery, and good contacts. Wonder if earphones make a difference.
How to relace BIOS battery ?
Turn off and unplug pc, and then remove the bottom of the laptop until you see a 3VDC Round Silver Wafer battery inside a clip. Simply remove the battery from this clip and reinstall a new 3vdc battery. Notebook cmos batteries are harder to replace than Desktop pcs, so be careful.Watch out so you don't lose the TINY case screws.
Aug 23, 2014 | Toshiba Tecra 8000 Notebook
My computer lost time and date after restart
The CMOS battery has died and must be replaced. Desktops are easy; laptops a bit more difficult. Most motherboards use a CR2032 3VDC button-style battery
Aug 01, 2014 | Intel Computers & Internet
Laptop battery charges for 30 seconds and then stops
Dear Lauren Monge
The problem is in one of two,1st charge plug in your lap or the adapter itself and its plugins
Best Regards
Mazagange
Mar 28, 2013 | Dell Vostro 1710 Laptop
Where can i get a replacement AC adapter for my sony walkman MZ-R70?
You web search for "Sony Walkman MZ-R70 ac adapter".
Lacking a perfect match find a 3vdc power supply somewhere like Radio Shack or eBay. They make universal ac dc adapters. Look around.
Aug 10, 2011 | Sony Walkman MZ-R70 Personal MiniDisc...
Will the ac adapter (3vdc) when pluged in, charge the rechargeable batteries while in the camera ?
No. If you use rechargeable batteries, you'll have to recharge them using a separate charger, not in the camera.
Jun 15, 2011 | Kodak ZD710 Digital Camera
My mp3 doesnt turn on or connects to the computer , how can i fix this problem ??
First, you have to find out why it doesn't "turn-on" before it could connect to the computer. The battery may be bad. If you have an external power adapter use it. If it powers ok, then connect it to the computer. If not, then the charging circuit is bad - it can't charge the battery as well as apply external power.
Feb 23, 2011 | Sony NWZ-S615F Walkman Video MP3 Player
I need a ac adapter for a Sony WM-FX193fp Walkman
Any +3vdc source with a positive center conductor will work if it fits.
Suppliers like Radio Shack would have power supplies and adapters to make them fit a variety of connectors.
EBay lists a zillion of them
http://desc.shop.ebay.com/Gadgets-/14948/i.html?LH_TitleDesc=1&_nkw=3v+ac+adapter+sony&_catref=1&_fln=1&_trksid=p3286.c0.m282
Feb 01, 2011 | Sony Walkman WM-FX193 Personal Cassette...
Walkman gx670 burned out?
The battery is more than likely burned out. If too much voltage goes through to them they will short out. Will need a replacement battrey. Try ebay, or a Sony dealer.
Rich
Aug 15, 2009 | Audio Players & Recorders
My Sony Walkman WM -SR10 is not recording and the cassette tape is not working. Only the radio is player. And I cannot get another one to buy even its not the same. Can you help me
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Nov 09, 2008 | Sony (Personal Audio) Walkman AM/FM Stereo...
Sony Walkman WM-FX290 Personal Cassette Player Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
