Question about Hoover AAA160 Front Load Washer
Cleaning washing machine filter
After a wash cycle, the clothes in my Hoover washing machine (HNL 6126) have a grey gooey substance on them. I think the filter needs to be cleaned, but I don't know where it is, or how to take it out! Can you help me please? Cathy
  • 188 Answers
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
  • 77 Answers
Hi cathy, gey an gooey can be grease from the drum bearing, if the machine empties ok i shouldnt think the filter will be the cause, hope this helps
Posted on Feb 10, 2009
How do I change pcb on Hoover Nextra HNL 2126 please ?
make sure u photograph were all the wires go back on with ie ure phone
Feb 13, 2015 | Hoover Nextra HNL 3166 Z Front Load Washer
After a load of washing the clothes are left with black deposits of plastic like substance on them.
Sure all pockets were empty before the clothes went in?
Normally there can't come any plastic in the inside of a washing machine.
Jan 18, 2015 | Hoover Washing Machines
HNL 3146 WILL NOT EMPTY AT END OF WASH
Hi davebmail,
It could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hi,My daughters washing machine (Hoover Nextra HNL 842) fails to empty after washing cycle.(error code 3). I intend to check the pump and float switch.I can access the pump through the bottom of the...
You should have a drain filter. They do become clogged and need to be cleaned out. If the draine filter is clogged you will immediately know it upon removal and inspection. If this is the culprit, be sure to show your daughter how to access it, remove and clean it and then to reinstall it. This can be quite frequent (8 to 12 months) depending on her environment, like allot of pet hair and things like that. Let me know if this is the culprit. By the way, you are going to have to bail as much water out of the drum as posible unless your model has an easy water shut off just prior to the filter. Otherwise, all the water left in the drum will run out of the filter assembly when you remove it. With any luck the filter is the culprit and not the pump.
Nov 21, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Smells grey sludge on clothes
its from all the old detergents not getting to the drain and lay in the outer wash tub,the smell is from mold starting to form in this gooey mess,you may need to remove the inner tub to get this goo out of the outer tub,then make sure the drain pump,hoses are also clean of this goop and there are no kinks,or blockages in the drain hoses or pump
Apr 29, 2010 | Bosch Washing Machines
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Feb 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hoover AAA160 Front Load Washer Logo
984 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
