Question about Philips Computers & Internet
Require new cutters forHq8100 - Philips Computers & Internet
  • freddavidge Feb 17, 2009
    thank you problem solved
  • Philips Master
  • 13,433 Answers
Hes in the UK ginko.
http://www.shavers.co.uk/sparessearch.php?search=HQ8100
Replacement Speed XL rotary cutting heads. Each pack includes all three heads to renew your shaver. ...
£35.23 (RRP £38.00)
on the above page.
If this is not what you where looking for let me know.
Posted on Feb 09, 2009
    Genius:
  • 1,011 Answers
Sir,
Contact this site for click this link
thanks goodluck
  • Philips Master
  • 19,396 Answers
Let me know your location, so that I can find a seller in your area.
I have a 2006 impala LT & I don't know how to get
Disconnect the tie rod and it should come off. Is this the type which has a metal band clamp holding it in place? Cut the band. New part should come with new clamp band which (wait for it...) requires a special tool to install, but can often be fitted by careful use of dull side cutters or bull nose cutters.
Oct 13, 2014 | 2006 Chevrolet Impala
What hp router is best to make cabinet raised doors
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
Cheers Capt Mark
May 10, 2014 | Makita RF1101 Electric Routers, Fixed &...
Auto retract slice cutter slider that moves blade out will not latch. I have to hold it in place with my thumb and so can't make any cuts. Am I missing something?
If I am reading this correctly, your answer may be that the cutter is designed that way for safety. "Auto-retracting". You find it in some utility knives that often store employees are required to carry so they won't "hurt themselves". Annoying, really. Try buying another cutter that is not an "auto retract"-- or get used to using your thumb for the purpose of holding the slide so the blade stays exposed.
Mar 23, 2014 | Slice Ceramic Safety Cutter
My blades are a little dull will the blades still cut through a bolt?
You shouldn't really be using dull bolt cutters because it requires more force to cut through the metal which increases the likelyhood that you will get an injury. Yes you can use dull bolt cutters but you should always make sure that your blades are sharp before you use them.
Nov 14, 2013 | Cutter Tools
What file size do I need to sharpen chain
It realy depends on the type of chain you have fitted, hobby chain fitted to small home owner saws is normally a 3/8 low profile and requires a 5/32 file, slightly bigger machines have a .325 chain and require a 3/16 file, big machines have a standard 3/8 chain and require a 7/32 file, the correct file should fit nicly into the cutter and sit slightly abobe, this will stop you file under the cutter head and creating a hook.
Feb 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
New foil required for braun 370 travel shaver
Hello MrandMrsInger! You can purchase a new replacement foil for your Braun 370 at the link I've provided below. Basically, you'll be getting a new cutter block and foil for it, as the foils are no longer provided separately.
Braun, now owned by Gillette, discovered that many folks would buy just the new screen (foil) and it would get torn/damaged by a nick in the cutter block blades, so they packaged these wear items as a set to eliminate those very common problems. I had it happen to mine several years ago, so I know why they made the change.
Anyway, here's the website with your replacement parts:
http://www.electricshaverstore.com/get_list_125.htm
Just scroll down to the 2nd item shown, I believe, and you'll see your replacement set.
You can also use the part numbers to try to locate another supplier, if you wish, as these are the actual Braun part numbers provided.
Hope you find this Very Helpful and best regards!
Oct 22, 2009 | Braun Health & Beauty
Cutter jammed
if you take the side off, and then the power supply, you will see a sensor and a flag, check for wear / damage. sometimes the allen bolt that holds the lower cutter linkage can come loose. try cleaning the sensor. also the connections from the cutter board need cleaning with ipa. if that doesnt solve the issue, you can take the cutter off, remove the silver plate and remove any label debris. if all this fails to solve the problem you will probably require a cutter board or sensor.
Jun 24, 2009 | Zebra 105SL Thermal Label Printer
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
Computers & Internet Logo
14 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
