Question about Dell Dimension 3100 PC Desktop
Msn 2009 my cam doesn't work with this msn,2009 first i thought it was my cam but it works with any other program.
  • Dell Master
  • 13,433 Answers
Hi
I personally haven't heard of msn 2009. I use messenger live, try another version of the program and it should work.
do you need a download link?
thanks,
ekse
Posted on Feb 09, 2009
I can't start my web cam i check the properties of the unit it says its working properly. i thought my web cam malfunction so i went to a computer shop to buy a usb web cam but still it won't work...
you just need to install virtual cam then go to manycam dot com and download manycam install it and select video source your web cam
now you can broadcast your cam on everywhere like skype, yahoo, msn, gtalk etc
by select manycam as your primary cam
good luck
Aug 20, 2011 | ASUS Eee PC 900 PC Notebook
I download the new msn messenger from the msn home page , so i know its a legit msn 9 , but after i downloaded it, and try'd installing it , it got 51 % done then stopped, it look like it's still...
lose MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Hope I helped MSN expert Dr Reed
Oct 12, 2009 | Microsoft Windows Live Messanger
My msn get automatically ofline
lose MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
I hope I helped MSN expert Dr Reed
Oct 03, 2009 | Microsoft Windows Live Messanger
Platfom isn't working on msn??
=? try this
close MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
Sep 24, 2009 | Microsoft Windows Live Messanger
Problems with web cam on Toshiba netbook nb200
update the program ...if the webcam works fine on other IM programs ..it means that the msn is the problem ...
Jul 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Dell webcam manager working with msn messenger?
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
I got a new msn
press the flying windows button on the lower left corner of the screen and press computer. It should appear under the drives if it was installed correctly.
Dec 18, 2008 | Acer Aspire 3610 Notebook
Crystal eye webcam
did you downgrade from vista
the cam will need to be setup with yahoo and msn
if your having problems installing the cam then try
camera-drivers.com
some vista programs will not work with xp and the same with some xp programs will not work with vista
so let me know if cam is downloaded and you just need setup on msn and yahoo
Dec 06, 2008 | Acer Aspire 5520-5908 Notebook
Toshiba Satellite A200-AH5 Troubleshoot
The type of pc is not as important as the type of webcam at this point. The story also needs more details.
If you had a Logtec webcam and at first it only worked with its custom made software, what did you do to make it work with MSN?
Based of the info provided, I would
1. uninstall all cam software while the cam is unpluged,
2. Reboot the pc. Then plug the cam in.
3. When windows detects the cam, it will ask for drivers, do not click on search on windows update website, click the option to choose from a specific location and then browse to the cd provided.
4. Try and load msn now. The msn website or the cam company sometimes have a patch to make the cam and the messenger work together. I would check the cam website before looking around the microsoft site.
Jan 11, 2008 | Computers & Internet
Problem with my webcamera
where can i find web cam and display drivers for VGN-CR11GH
Jun 24, 2007 | Sony PCGA-UVC10 Webcam
Dell Dimension 3100 PC Desktop Logo
65 people viewed this question
Alun Cox
