Question about GE WBSE2090A Top Load Washer
My washer is leaking grease or oil on the floor under the machine
My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. Thanks for any help.
  • vignerons Feb 23, 2009
    Ge top load washer is running but leaking oil. I have seen on the web that GE recommend replacing the transmission, but other people have said you can replace the seal. I would like to know more. I have opened the cabinet and I am trying to remove the drum but cannot get by the agitator.
    My product number is WSKR2100TBWW.
  • 750 Answers
Hello and welcome
You said, My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. If the gear oil is leaking this usually means the transmission is shot and on it's way out. It is not cost efficient to have it replaced. 99.9 % of the time you throw it out and buy a new washer.
For the cost of the Transmission and the labor.
you can buy a new washer.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Posted on Feb 09, 2009
  • 1,031 Answers
Oil under the washer is not a good sign. The first thing to do is to disconnect the washer from the wall outlet, remember that safety should come first.
Remove the front panel of the washer. To do that, you could use a spatula to release the front panel holing clips. These clips are about 3 inches from the sides of the front panel. Insert the spatula between the top and the front panels and push the holding clips until they release the front panel.
Remove the front panel and use a drop light to illuminate the area under the washer. If the oil is leaking from the transmission seal, it will be all over the transmission pulley, the belt and the clutch assembly.
The correct procedure will be to replace the transmission and the belt. That in my opinion is too expensive to do, probably will be better to get another washer.
Now, if the oil leak it is small, what you may be able to do, it is to remove the belt and use degreaser to clean the transmission pulley, the belt and the clutch. Then reinstall the belt and adjust it. This may buy you time before you need to buy a new washer. Use baby powder to dry the belt before installing it.
I will not worry much about putting any oil in the transmission, jus run the washer it until you can't use it any more. Install the front panel and try the washer to see if it works better. These washer are not made like the older ones,
  • Starnley Johnwells
    Starnley Johnwells Feb 09, 2009
    When a washer is leaking, there are several areas where the liquid could be
    coming from.
    If it only leaks during a spin cycle, it's probably caused by a leaky drain
    Over-sudsing is a common problem in homes with a water softener. Soft water
    and hot water use less detergent, while hard water and cold water need more
    detergent to clean well. This product, SofChek, will help
    you to determine if you have soft or hard water in a minute or less. These
    easy-to-use strips measure the hardness of your water in less than a minute.
    Just simply look at the colour chart provided on the bottle for an instant
    read-out of the strip to help determine the proper amount of detergent. Lowering
    the amount of detergent used may alleviate any over-sudsing issues.
    Leaks on a front-load washer can occur around the door seal. This can happen
    because of a build-up of dirt and soap on the seal itself preventing a proper
    seal from taking place. Wipe the door seal carefully making sure that the edge
    of the gasket is clean.
    Parts of a plastic bleach dispenser can crack or break off, causing a leak
    intermittently during the flush process. This is because bleach is a very
    corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust
    stainless steel parts. Consider switching to oxygenating bleach, although this
    type of bleach doesn't get your whites as white as they can get with liquid
    chlorine bleach. The bleach dispenser is a replacement item.
    You'll want to confirm that the fill hoses are connected and properly
    tightened. Always use new rubber washers when re-installing the hoses. Take care
    not to over-tighten the connection. Other leaks may be caused by the drain hose
    being cracked, or by a leaky connection at the water-inlet valve. Too many suds
    may cause the appearance of a leak when actually it's just a sudsy overflow.
    Sometimes a drain hose leak occurs at the end of the hose where it attaches to
    the washer. If the hose is long enough you can cut the leaky end off and
    re-clamp the hose back on. Usually though, when a hose begins to leak, it is
    best to just replace the hose.
    Many pump leaks happen around the seal on the pulley. Some pumps have a weep
    hole that lets water drip out when this seal begins to go bad. The solution is
    to rebuild or replace the pump.
    Tub leaks are usually caused by a rotted tub. If this is your problem,
    consider buying a new washer. Sometimes a constant imbalance can be the culprit.
    This imbalance can rub a hole in the tub if it consistently runs off-balance. It
    may be possible to repair the tub with an epoxy kit. Tub replacement isn't
    usually very economical.
    The main tub seal can also leak. This is located where the transmission and
    the outer tub in the centre. If this seal goes bad, it can be very difficult to
    Sometimes the water-inlet valve develops a buildup of mineral deposits and
    rust. To check this, remove the water-inlet valve and visually inspect the
    hope this helps
I have oil in my radiator- is it the oil cooler?
if it is pink or tan colored yes
replace the radiator and have the engine and heater system professionally flushed
Jul 06, 2017 | Cars & Trucks
97 GMC Jim 4x4 oil leak not noticeable from top for sides of eng can't c where its coming from underneath either u told me it could b r c gasket where is that located on eng v6 no knocking from eng
is it an oil leak or other fluid --under engine you have the oil filter - power steering lines-transmission pan ,lines -transfer case -front c/v axles and center ham -coolant-brake fluid-and gas all these lines are at the back of the trucks engine you need to look at whats wet and where to pin point a fluid leak best is by color trans-power steering usually redish --oil, transfer,axle,blackish ---coolant green or red --brake, tan
Aug 16, 2016 | GMC Cars & Trucks
Engine is making oil
An engine does not make oil, but it can spill the oil that should be inside. You could have an oil leak, which means that oil will be leaking from either the front or the rear oil seal. The front oil seal is just behind the crank pulley, the one that drives the fan / alternator belt. If oil is leaking from there, suspect the front seal.
If you have oil leaking from the bell housing, that the the bell shaped metal thingy between the engine and the gearbox. you can suspect the rear oil seal.
If you inspect the engine and see oil leaking from the oil pan under the engine, you have a leaking pan gasket. This can usually be solved by tightening the pan bolts, a whole lot of bolts underneath the engine.
Finally, and this is probably the worst, if you see oil around the breather pipe that goes from the valve cover on top of the engine to the gas intake system, you have leaking compression, that means either the valve stem seals are leaking or the compression rings are finished, and you will have to have the engine overhauled, or at the very least have the cylinder head overhauled.
If the rings are suspect, you will also have excessive smoke out of the exhaust when you drive, especially when you accelerate. Check the exhaust for signs of wet oil.
Mar 18, 2015 | Cars & Trucks
Oil leak 2000 alero, just replaced plug, not it, leaked out all the oil after I drove it 20 miles, please help, could it be a gasket or what
Check the oil filter. The old gasket might be stuck on the engine (two gaskets stuck together), or the new gasket might be defective, misaligned or missing.
Nov 05, 2011 | 2000 Oldsmobile Alero
Increasing use of water from the radiator reservoir
One thing to check is for coolant getting into the oil, which would indicate head gasket failure. Check oil dipstick and/or underneath of oil cap for a frothy brown/tan look to it. If so, do not drive the car.
Also check coolant reservoir for a leak. Evaporation is suspect, but maybe not to the point you are describing. Check coolant reservoir cap, as well as radiator cap.
Apr 26, 2010 | 2000 Volkswagen Golf
Leaking grease
All washer machines have a "transmission" - just like a car these units have oil in them and when the seals that protect the oil from going to our clothes is breake, oil finds its way to your clothes.
Transmission needs to be replaced.
Aug 18, 2009 | GE Profile WPRE6100G Top Load Washer
Fairly new ge washer spitts out grease/oil from under agitater
Remove the agitator and inspect the upper shaft bearing condition by trying to push the shaft in various directions. It should not be possible to observe movement in a good bearing. If the bearing looks good, then replace the rubber seal just under the plastic block on the shaft top. You must be very careful not to damage the shaft where the seal lip rides. If the bearing is loose, the machine must be torn down to remove the shaft from the supporting post.
Aug 15, 2009 | Washing Machines
Grease is leaking under my GE washer.
this sounds like the bearings have worn-out.
Jul 13, 2009 | GE WBSE2090A Top Load Washer
GE WBSE2090A Top Load Washer Logo
4,841 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
