Question about Business Objects Crystal Reports Developer 10 (dlucc010) for PC
Formatting of cross tab reports
I want short line to appear on the top of specific itemname which is part of y-axis i.e. row.
Item_Description | Value 1 | Value 2
_________________________________________
ABCD | 1234 | 23456
pqrsd | 2346 | 456547645
Total a | 234234 | 876
djfhgkdjhfg | 734657 | 908987
TOTAL |09586 |3498793875
Expected output
__________ ______ ______
Total a | 234234 | 234234
Is the above specified formatting (short line above ''Total a'' and value 1, valu 2 is possible in cross tab reports.
How do I sell on gumtree.
click on gumtree , click on sell tab and fill out the form work on line
photos of the item and a reasonable price ( not the excessive price that you want but close to market value will get buyers
an honest good description of the item is attractive to buyers
it is free but there are options to keep the ad at the front so it depends on how fast you want to sell
Nov 14, 2017 | Cars & Trucks
How do I set the fax confirmation with image on a Samsung SCX4521f multifunction printer
Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
MSG Confirm
You can set your machine to print a report showing
whether a transmission was successful, how many
pages were sent, and more. The available options are
On, Off, and On-Err, which prints only when a
transmission is not successful.
Image TCR
You can prevent the Image TCR from being included in
the confirmation report for privacy or security
protection. The available options are On or Off.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear
Jan 21, 2015 | Samsung SCX 4521F All-In-One Laser Printer
X and y intercepts
First of all you equation is not one : it has nothing on the right side of the = sign. But to answer the general question let us write the equation as 50+25x-5y=0
X-intercept (also know as roots) There may be several
Definition: X-intercepts are those values of the independent variable x for which y=0. For a straight line there con be at most 1 x-intercept.
To find the intercept, set y=0 in the equation of the line and solve for x
50+25x-5(0)=0 or 50+25x=0. The solution is x=-(50/25)=-2
Y-intercept (also know as the initial value. There can only be 1 y-intercept, otherwise the expression does not represent a function.
Definition: It is the value of the dependent variable y when x=0 (where the function crosses the y-axis
To find it, set the x-value to 0 in the equation of the line.
50+25x-5y=0
50+25(0)-5y=0, or 50-5y=0. The solution is y=50/5=10
The straight line cuts the x-axis at the point (-2, 0) and the y-axis at the point (0,10)
Jan 28, 2014 | Computers & Internet
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
Jul 12, 2011 | Sewing Machines
My ti 84 graphs the line but will not show the x and y axis please help!
Above the top row of keys one option will be Format (I believe 2nd and then Window). You can turn on and off the axes in this menu.
Jan 22, 2011 | Texas Instruments TI-84 Plus Calculator
Why is it true that at x-intercept, the value of y is0, and at y-intercept the value of x is 0?
The x intercept is where the value of y when graphed lands directly on the x axis. The value of y anywhere on the x axis is zero. The same is true for the y intercept producing an x value of zero. The point at which the graphed line intersects the y axis gives an x value of zero. The value of x anywhere on the y axis is zero.
Jan 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
I WANT THE WHOLE CODE FOR THIS
This whole code for above we can not give.
Aug 06, 2009 | Shopnovell iFolder 1.0 Software Media Kit...
Conditional Formatting doesn't work until I select the item
the mouser is equip with shortcut of any of program by using right click pointing to item.
Oct 15, 2008 | Microsoft Office Professional 2007 Full...
Macro
Hi alwinkumar
You can set a default value in most form items under the properties of that item. Look for "value". You can also do this in code, by setting up a sub routine to set/reset the values on your form. Then just run the sub routine before you open or enter the form.
Private Sub resetForm()
'formname.itemname = value
UserForm1.Label1 = "Hello World"
End Sub
For the second one you have a couple of options, you can find the bottom on the data and store the row index in a variable, use a loop to find the next empty cell in a row, and store the value or you can use the current region method to select all the cells with data continously touching the selected range. Example below
numberOfRows = Sheet1.Range("A1").CurrentRegion.Rows.Count
Jul 16, 2008 | Microsoft Office Professional 2007 Full...
Business Objects Crystal Reports Developer 10 (dlucc010) for PC Logo
Top Business Objects Computers & Internet Experts
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
