Question about i-mate JAQ Pocket PC
Imate jaq gprs and outlookmail settings
Hi iam chetanya iam using imate jaq with idea service provider i want gprs and outlook email settings
    Guru:
  • 832 Answers
Hi thanks for using fixya!!!
I really suggest if you can contact your Network Service Provider to send you the setting of your GPRS, they can send you over-the-air or you may call them or drop by to their offices and they can set it to you manually. It will be easier and will be more specific.
Hope it helps, if you need further, let me know.
Don't forget to rate my simple solution positively! thanks!
Posted on Mar 16, 2009
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
How do get gprs settings for my imate 8502
Well you need to contact costumer care of your service provide only they can send you the GPRS and MMS settings, they send you a message of GPRS and MMS settings you just need to save that message to your phone....... So call now to your service provider costumer care and ask them for that settings........
Note. GPRS, MMS or Internet settings are always provided by the service provider....
Thanks for using FixYa
Feb 13, 2010 | i-mate Ultimate 8502 Cell Phone
Conection of GPRS
Download imate-configurator from the imate website.
Go to: http://www.imate.com
  1. Enter your country name
  2. Select "Support"
  3. Select "Device Support"
  4. Select "Your Phone"
  5. Select "Patches"
  6. Download i-mate configurator
install the cab file in your device, the settings will automatically be done.
You may then connect to the internet.
Please rate if this helps you...
Jul 23, 2009 | i-mate JAQ Pocket PC
How 2 activate internet in imate mobile
how can i open my internet of i mate jaq if yes, then plz tell me urgently
Jul 20, 2009 | i-mate JAQ Pocket PC
Gprs setting
hi thanks for using fixya!
I recommend that you should contact your Network Service Provider and ask them to provide you the GPRS configuration and settings.
If you need further assistance, let me know!
May 07, 2009 | i-mate PDA2k Pocket PC
GPRS setting for Imate JAQ
i have aitel sim card. please give guide for internet mobile office setting
May 21, 2008 | i-mate JAQ Pocket PC
Issue with imate JAQ
Dear Have u got ur GPRS or EDGE service activated from AIRTEL. Pls confirm it, if yes then following are the settings for airtel.
go to
>>START>>SETTINGS>>CONNECTIONS
connections>>Add a new Modem connection
>>Enter name-airtel or Mobile office
>>select a modem>>it should be Cellularline (GPRS)
>>NEXT
>>eNTER THE NAME AS IT SHOULD BE DIALED
>>enter airtelgprs.com (all small caps)
>>NEXT
>>FINISH
NOW again go to START>>SETTINGS>>CONNECTIONS>>connection>> Advanced>> select networks
There will be two options
1-prog that automatically connect to the internet
2-prog that automatically connect to a private network
>> for both options select >>My ISP
>>tab OK
Feb 29, 2008 | i-mate JAQ Pocket PC
I-mate jaq
my imate jaq doesnt connect to my pc. Is this a problem related to drivers. If yes, then I suppose the installation cd does contain a driver please advice.
Jan 18, 2008 | i-mate JAQ Pocket PC
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
i-mate JAQ Pocket PC Logo
142 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
