Question about Sony DSR-1500 Mini DV VCR
DSR 1500P problems loading tape
Have been repairing similar professional machines. However i dont have the service manual for DSR1500.
I have tried loading and unloading the tape in service support mode in advanced menu and tape loads normally. i have also checked the operation of the cassette compartment sensors in service mode and they are fine. However when I exit the service support menub and i try to use the machine normally, no voltage appears on the cassette compartment motor when the tape is inserted. the tape is therefore not loaded.
  • 3 more comments
  • Luwangula Feb 11, 2009
    can anybody get me a .pdf or .rar copy of the DSR-1500P service manual?
    has anybody out there got a free pdf or RAR copy of the service manual for DSR-PD150P?
  • Luwangula Feb 14, 2009
    The front [anel indications are normal and there are no error codes
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    In my opinion, you should purchase related service manual ( there are 2 manuals) to repair this unit.
  • 4,234 Answers
Are there any indications on the front panel at all? There should be an error code of some sort there. If not, I'll need to research this a bit. Please update this with any codes.
Thanks,
Dan
Posted on Feb 09, 2009
  • ABRsvcs Feb 14, 2009
    OK I did some checking with others about this one and they are a bit stumped too. The only thing we came up with is perhaps a fault in the mode gearing/switching that is on the top of the cassette housing. Try spraying out that mode switch.
    Based upon your description, the unit is not detecting the correct mode. I know in standard VHS machines, I have seen this when the mode switch contacts are dirty. With the cassette partially loaded, the mode switch is less of an issue and the sensors indicate partial load so the load sequence is competed.
    Keep us posted.
    Dan
Tape stuck inside Sony VX2000
If you are on about the VX2000 which is similar to the professional DSR-PD150 remove battery or supply then simply apply 3volts to the main mech drive motor and unthread the mech from the load position you will notice if it is in the load position because tape will be laced around the drum assembly hence the fact you can not remove the tape
John www.jvsvisual.com
Apr 02, 2013 | Sony DCR-TRV285E Digital-8 Digital...
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
Mar 22, 2010 | Sony DSR-1500 Mini DV VCR
Error 95-744 on DSR1500 AP sony
Main code 95 : Digital signal process system error and communication error with ICs
7 : STANDBY-OFF mode
4 : Capstan motor/FG
4 : FG cannot be detected.
Nov 07, 2009 | Sony DSR-1500 Mini DV VCR
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Sony DSR-1500P does not load tape
There should be smoe indication on the front of a problem. If not, then the load sequence is not completing and the unit should be sent in for service. These are pro decks that should only be serviced by trained personnel. There are a number of reasons why a taoe would not load. Without seeing the unit, it is extremely dificult to determine the cause. Are there any other details you can provide that might help me to determine possible causes? Can you observe the loading to see how far it gets?
Thanks,
Dan
Feb 05, 2009 | Sony DSR-1500 Mini DV VCR
DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Feb 26, 2008 | Sony DSR-25 Mini DV VCR
DSR-11 pixelates on right side of Screen
most likely problem is a misadjusted exit guide post. cleaning would not solve the problem; if you have a service manual and know how to adjust the guide, you can do it yourself. otherwise, it's a job for a technician with the proper test equipment.
Dec 20, 2007 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-1500 Mini DV VCR Logo
394 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
