Question about Canon imageRUNNER 400S Copier
Error : e051
Pls let me know about the error mentioned above.
thanks
  • naazprint Feb 09, 2009
    sir, I have a cannonir400 copier. please help me in solving the problem of e051 error.
    thanks
    Sergeant:
  • 199 Answers
This error occured when -
The home position cannot be detected after the horizontal registration signal has been sent.
because -
1.The horizontal registration sensor (PS10) has a fault
2. The Horizontal registration motor (M9) has a fault.
3. The DC controller pcb has a fault.
To solve first check sensor & motor
Posted on Feb 15, 2009
Error code e051
the horizontal registration home position detection mechanism has a fault
May 01, 2014 | Canon imageRUNNER 400 Printer
Toshiba estudio 167 E051
E051 use to be a false duplex jam on the IR-550 and was always a bad MSW5 switch causing the problem
Sep 20, 2012 | Toshiba Office Equipment & Supplies
How to solve E051 error please guide me...my machine is canon ir 400, problem started immediatly after starting the machine, i cleared the error by pressing addl fn+2+8&addl.fn but it didnt solve it....
This is failure of the horizontal registration motor. I've had to replace this motor and it's a very involved process. This is the very small motor located just above the paper pick-up assembly. If you're not a qualified tech then let a tech take care of it for you. You have to remove several covers, P/U assembly, and other things to get to it.
Jun 27, 2011 | Canon imageRUNNER 400S Copier
Just got this used canon imagerunner 330s. It seemed to be working OK but now wont finish powering up and displays an E051 code. Can I clear or bypass this? What does this code indicate? Thanks, Keith
Error code E051 indicates there is a problem with the movable paper guides in the duplex unit. Check that the rear connector for the Duplex unit is clear of paper or toner
Feb 16, 2011 | Office Equipment & Supplies
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
My mich suddenly shows that E051 error can any one help me
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again there is a small motor that drive the sensor assy should be change.try to move the sensor manually by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 07, 2009 | Canon Office Equipment & Supplies
ERROR CODE E051
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 03, 2009 | Canon imageRUNNER 210S Copier
CANON GP 405 ERROR E 051
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
E051 sensor location
It is located behind the paper pickup unit on the pre-registration guide. There is a teeny tiny motor with a tiny plastic gear and the gear cracks which stalls the motor. The purpose of the sensor and motor are to find the front (or is it rear?) edge of the paper coming out of the duplex unit so it can accuratly line up the images on the paper.
Apr 03, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER 400S Copier Logo
345 people viewed this question
old marine
old marine
