Question about Honeywell HZ517 Baseboard Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
My two Honeywell HZ517 Electric Baseboard Heaters will not turn on and they stopped working at the same hour. Was this defect built into the product during manufacturing in China?
    Problem Solver:
  • 12 Answers
First.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Posted on Sep 29, 2009
2 Suggested Answers
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
Not heating up... what could be problem....some simple i hope
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future.http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/ not-heating-up-could-problem-some-gwybjxudtwjfkyidrgix5fxs-4-0.jpg
Oct 23, 2013 | Honeywell HZ514 Baseboard Heater
How do I connect two baseboard heaters to a programmable thermostat?
You have switched 2 of the wires, reverse them.. If you had it working once, then it will work again
Apr 12, 2013 | Honeywell Heating & Cooling
Need to replace off switch
I hope this is a solution for you, and you are safely warm again in the near future. need-replace-off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg
Mar 12, 2013 | Honeywell HZ514 Baseboard Heater
Off switch
I hope this is a solution for you, and you are safely warm again in the near future. off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Need a thermostat for model no hz-514
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
It won't turn on
these operate on 220 volts.be very careful. you have to check is it getting power?is power getting threw thermostat?if both answers are yes then element is bad.
Jan 12, 2011 | Honeywell HZ817 Electric Baseboard Heater
The unit wont turn on at all, no power. The outlet works
Bad Plug
bad cord
burned internal connection
bad thermostat control
over temp fuse burned out from overheat (safety device)
Jan 07, 2011 | Honeywell HZ517 Baseboard Heater
I have a electric baseboard heater and when I turn the thermostat up, it heats for awhile and then the heater stops throwing heat but never reaches themperature. Changed thermostat and still the same...
you either have an overheat switch opening up prematurely or a bad connection that faults when it gets hot. Check all connections with the power off and try jumping out the safety switch to see if the heater stays on.
Feb 28, 2010 | Honeywell Heating & Cooling
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
Honeywell HZ517 Baseboard Heater Logo
694 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
