Question about Sony DSC-T70 Digital Camera
DSC-T70 DSC_T70 I have white spots on my photos.The lence is clean and checked by a technician. Maybe their is a settings problem?Any help?
  • Sony Master
  • 19,396 Answers
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Posted on Feb 09, 2009
Installed new screen and have no picture only white screen
A white screen is the result of the LCD cable clamp not
securely fitted in the Cable clamp (for the DSC-T70)
Oct 04, 2011 | Sony DSC-T70 Digital Camera
All of our photos turn out with a blue tinge
You may have the white balance set to something other than "auto white balance".
May 02, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
I replaced LCD in my Sony DSC-T70 and i still have a white screen
HI samminowak Where did you buy the LCD for DSC-T70, can you provide me a link? I decided to put to the support store recommended by Sony Tech Support authorized dealers. Did u try to contact them?
Dec 10, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Sony DSC T70 only holds 33 photos with a 1GB memory card... WHY?
There's probably something else taking up a ton of space on that memory card. Format it with the camera if you aren't worried about losing data. Otherwise, plug it into a computer with a memory card reader and see what's taking up the space.
Sep 13, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Outdoor images overexposed
hi, its a problem of lence flap,it is in the lence berral , just change the lence flap and your camera is ok,remember if you are a tecnition then try your owen
Aug 27, 2009 | Sony Cybershot DSC-T200 Digital Camera
SONY DSC-T70 blank screen! touch screen camera T^T!
The same thing happened to my Sony DSC-T70 today after I dropped it. White screen with green vertical lines. Need help!
May 11, 2009 | Sony DSC-T70 Digital Camera
White spots on photos
Feb 09, 2009 | Sony DSC-T70 Digital Camera
Sony dsc t70 flash problem
Because you have set the multi photo mode.
when you set it back to single shot mode, then the flash menu will change to more option to turn on flash.
it's because the camera can not charge the flash fast enough to do a few shot per second if flash is on.
This is the same as other digital SLR camera.
Oct 15, 2008 | Sony DSC-T70 Digital Camera
Sony DSC-T70
Pretty Simple:
Option 1. Go to preview mode, use the zoom-in button to see the thumbnail view. Then press delete button. You will get an option of delete-all.(it deletes all the photos except the ones specifically protected. You can remove the protection through menu options)
Option2. Another option is to connect to PC, navigate to the chip and delete everything in the folder (and not the folder structure itself ;))
Hope this helps.
Jul 13, 2008 | Sony DSC-T70 Digital Camera
Sony DSC-T70 Digital Camera Logo
79 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
