Question about Sony DSC-T70 Digital Camera
White spots on photos
I have white spots on my photos.The lence is clean and checked by a technician. Maybe their is a settings problem?Any help?
  • Sony Master
  • 19,396 Answers
No setting can cause white spots on the picture, this is a fault.
By the way you can reset settings on this camera to initial state by simply removing and putting back camera batteries.
Alternatively you should have a reset command on camera settings menu.
My opinion is that this is a fault and not a settings problem.
Typically there are three kind of faults that can cause this problem:
1 - Dirty lens or water inside the lens:
The lens may be dirty inside, for example because of water condensation on internal surfaces, this will cause blurred dots or black dots. The lens must be taken apart and cleaned in this case.
2 - Defective CCD sensor.
The CCD sensor is the chip that detects the picture, if you get well defined white or colored spots on picture that is probably a defective CCD. I think this is the more likely in your case. To fix this the sensor must be replaced.
3 - Defective video chip on internal board.
This can cause any kind of problems, however it is quite unlikely.
It is an expensive repair.
Posted on Feb 09, 2009
What should I do to clean my oven?
You can use Easy Off 'Fume Free' oven cleaner on a self-cleaning oven, if you want to manually clean it, but do not use it with the self-cleaning cycle.
Apr 26, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
How to clean lence whit spots on screen
This is a dlp projector and has a bad DMD chip. Most models are very similar. Here is a video of a similar repair.
Feb 02, 2014 | Acer P5271 PROFESSIONAL...
White powder-like substance on belt
Dear Sir:
LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well.
4) Test the input motor if there voltage the motor need repair.
God bless you
May 09, 2012 | Proform XP CrossWalk 580 Treadmill
Outdoor images overexposed
hi, its a problem of lence flap,it is in the lence berral , just change the lence flap and your camera is ok,remember if you are a tecnition then try your owen
Aug 27, 2009 | Sony Cybershot DSC-T200 Digital Camera
DSC-T70
Feb 09, 2009 | Sony DSC-T70 Digital Camera
White spot on photo
Hi and welcome to FixYa,
Initially, this would be a temperature imbalance on the CCD lens. Often white spot(s) appear at night or when the temperature is cold. Workaround is to open the lens but delay taking a picture after a few seconds. The idea is allow the lens to match the ambient temperature.
Good luck and Thank you for using FixYa.
Jan 09, 2009 | HP Photosmart 315 Digital Camera
White Spot
If this white spot is always exactly the same, but moves off the picture when you start to digital zoom and not optical zoom, there is probably something on the sensor. You mentioned that when zooming, eventually it moves. Are you in digital zoom mode at that time? (The switchover from optical to digital zoom is automatic, but you can disable it). Is this white spot blurry or sharp? Can you see fringes of the image at the edges? (This would suggest something on the lens).
If there is a piece of dust inside the lens ,you may be able to see it looking down the lens. How big is this spot?
Either way, if the camera is new, can you still return it?
May 28, 2008 | JVC GR-D244 DV Digital Camcorder
White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Bright white "photos"
I too have same problem & Same model, When i checkup with service center, they say it is Shutter problem. It cost $50 to rectify. They replace the Shutter. To replace the Lence unit they charge $ 80.
Mar 24, 2008 | Nikon Coolpix 2500 Digital Camera
Sony DSC-T70 Digital Camera Logo
191 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
