Question about Adobe Photoshop 7.0 for PC
Charging system My Zetel N95y+ cannot charge, the charging system has died of and i have to charge the battery on a separate phone, to make it worse i bought an original Nokia battery to see if it the charge can stay for a longer duration, but to my dismay this did not happen. The ear piece and the mouth piece have problems to. Sometimes i have to shout on top of my lungs to pass on my message, and at times i can hardly hear the person on the other end. Honestly, if this phones are this fake, why are they being allowed to circulate the market.:-( :-|
  • 21 Answers
To the battery issue, if your phone uses a Ni-Cd battery, those do fail to work to its full potential after one year. Less especially if you had not trained the battery. This means that you were to charge the phone to full power which is to not use the phone and not have it on but charging for at least 15 hours. then to use the phone till it dies. Draining the battery. Then charge it and repeat that process once or twice more. And the reason you would do this extreme thing is that Nickel Cad batteries keep a memory and if you use the phone and when it was at half battery you plug it in and start the recharge the battery takes note of that and then knows that at the mid point of its life it needs to be refreshed, and then your new battery becomes a old one because its lifespan got shortened by you.
So if your battery is failing or does fail to charge and/or the charge doesn't work for long is for that reason. best thing to do is not buy a new charger for an old battery, its time to buy a new battery. Or in your case buy a new phone.
-Luke
and if you could shyet_05 can you put your question concerning battery in the correct category, because this question is under:
All Products > Adobe > Photoshop 7.0 for PC > Troubleshooting > Problem >
and to those is nothing dealing with a Nokia phone's battery.
Posted on Feb 14, 2009
IPhone 5 was working perfectly, but when I plugged it in to charge, it didn't start charging. I could still use the phone. Now the phone died and nothing happens. Is the battery dead (as in broken)?
I would guess that you battery is fine, it is either your charger is not working or worse case your charger socket on you phone is damaged. Try connecting your iphone to your computer via the USB port and charging cable, if your phone starts to charge you know you have a problem with the plug side of your charging cable which is where your transformer is. Be aware that if your battery is totally flat it could take several minutes before you hear the beep from your phone to indicate that it is charging. If that doesn't work it could be your charging lead that is damaged so try charging with a different lead. If still no joy then you could be in trouble as the charging socket is soldered to the mother board and could be an expensive repair so fingers crossed it is only the charger that is damaged.
Jan 02, 2014 | Apple iPhone Smartphone
How long should i charge a new optimus black
The optimus black phone should take 2-3 hours to fully charge. When you get a new phone, however, it is generally a good idea to let the battery completely die before you start charging it.
Over time, batteries hold less and less charge. Supposedly, by allowing the battery to completely die before charging it the first time, you improve the longevity of the battery.
Feb 10, 2013 | LG P970 Optimus Titanium Black Android 2.2...
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 19, 2013 | Motorola Mobility Motorla MOTXT912 DROID...
Nokia 5800 not holding charge
First Option:
Second Option:
Sep 13, 2012 | Nokia 5800 XpressMusic Smartphone
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
I cannot use my flash ligth in my Zetel N95y
Push the zero button for few seconds in the main view.
Dec 05, 2009 | Adobe Photoshop 7.0 for PC
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Side kick not charging at all ?
the Sidekick 3 has a charging issue that crops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
YOu can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 16, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
Apr 29, 2009 | Samsung SGH-a737 Cellular Phone
Battery died and or charging system failure
I think its probably your only choice, NIMH batteries are known to have a very short shelf life if not regular charged / discharged you can get GE cordless batteries here - GE Cordless battery
Jan 10, 2009 | Uniden Cordless Phone
Adobe Photoshop 7.0 for PC Logo
79 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
