Question about 2wire 2700HG-B Router (2700HGB)
AT&T 2WIRE MODEM/ROUTER SUCKS
Do yourselves a favor and buy something MORE DEPENDABLE/ STABLE.
This thing is totally unconfigurable compared to my old DLink which was connected to AT&T's stupid Speedstream modem . . . I NEVER had any problems until their modem went. Figured it was easier to just have both modem & wireless router in 1, so I had the tech just give it to me off of their truck . . . dumb dumb dumb I have never had SO MANY PROBLEMS! There is no way to turn the firewall off unless you DMZ, for whatever reason, the WPA doesn't work - completely blitzes out the stupid thing & changing the WEP passphrase from the default freaks it out - even when the AT&T guy tried to do it. He was here for 3 hours trying to set it up himself (and he did have quite a bit of knowledge - I'm a prof dev, so know what I'm doing too)
I HATE THIS THING!!! Ready to throw it in the garbage really soon - never mind the $80 they charge you for it! PIECE OF JUNK - so save yourselves the trouble!!!
  • 3 more comments
  • Anonymous Feb 25, 2009
    I'm running the 2Wire modem that I recently got because I got the Homezone....I use to have the regular DSL with a Dlink router connected. Since I got the new router, certain games will crash my internet on my Macbook Pro. I've called tech support 3 times now, and each time, they cannot find the issue. Anyone have any idea?
  • Anonymous Mar 17, 2009
    keeps disconecting
  • Anonymous Mar 30, 2009
    No solutions - I was just complaining that it's a peice of junk. Still have it, but looking at a DLink product instead to replace this. I am used to making whatever changes/ configurations I want - this seems to just be a stripped down product w/ more or less 'fixed' options to choose from. To confirm after much research, there is absolutely NO WAY to turn off the firewall, as per 2wire - and the range on this thing is horses**t! Bought a Linksys range expander (after researching many) and NONE apparently are compatible w/ this stupid 2wire junk, so I'm out of that $$.
    I just wanted to give people the heads up on this - so they can avoid getting stuck w/ it. Unless you have 1 or 2 computers within close range of the 2wire (for wireless networking) or you have an ethernet cable plugged into it directly AND you're truly a novice, it's fine - otherwise, save your money & look into alternatives. The best one I found to date that is a wireless modem/router combo is the DLink product - for about the same price. NewEgg occasionally has special deals & quite often, free shipping on it.
  • Anonymous May 21, 2009
    I am having this same problem. Where games, VOIP, xbox live, etc will all crash/diisconnect and the tech support cannot detect the problem.
  • Carl Navarro
    Carl Navarro May 11, 2010
    You're preaching to the choir here. I feel better that you never got through the firewall, I couldn't either :-)
    Since the 2wire was a temporary solution until the site remodeled with new equipment, we just stuck a Netgear in front of the 2wire and used logmein.com as the access through the network.
I'm a tech and deal with the 2wires all the time. for one every router has the same so/called "firewall" that 2wire has. It's not really a firewall in a sense (every port is blocked on every router it just needs to be told which computer it has to be sent to) which you can either forward the ports or set it in DMZ mode which sends all ports to one computer (unless being sent to another)
WPA works just fine on the 2701 as it does any other router. I've setup a little over 100 computers with it.
As far as wireless working other places and not yours, we have to start understanding that a router in a sense is a basic device, they all work *almost* the same. I've come to a few problems where some computers give connected but limited or doesnt even ask for a key at all
main reason
1(EFI, cordless phone sitting right next to it, move it 3-5ft instant fix)
2(Channel, most routers in the US are either set to 6 or 1 same with the 2wire, change the channel to something a neighbor isnt using)
3(WEP Encryption, you would be amazed with how many computers for some reason have a problem with WEP, seems like the bugs have been fixed with WPA, switch to WPA (not WPA2)
2wires have the ability to increase//decreast the range with the power setting, it has 3 antennas inside of it and can reach the range of just about any other router.
sadly I've been doing this job for a long time this is how I know this stuff. trust me, same problem you're having here can happen to any other router. If you've been using another router thats worked fine I'm sure it's set to a different channel. or something else as simple as that,
I hope my information helps you, I've had a lot of success with the 2wire gateways and other routers, only time I've every seen one fail after playing with the settings is because the people lived under heavy powerlines, which scrambled the data being sent in the air so bad non of my routers worked.
Posted on Mar 07, 2010
  • sbhagi2001 Feb 19, 2011
    I have a DSL Westell 6100 and Router Netgear model MR814v2 and for a long time I have been getting problem of droping of signal strength. I spoke with ATT rep they said the problem was with my wireless phones. They said buy 2wire modem router set to solve the problem. Comment by a writer here suggested I move wireless connect more than 5 ft away from the wireless router. That is what I did and now the signal strength is just fine. You saved me spending $100 on new router. Thanks.
I was having a problem with my at&t 2 wire modem and I was told to replace the power supply cord. I picked up a universal ac adapter at wal-mart for $15 and it fixed the problem. Everything is working good now.
Posted on Feb 21, 2010
No solution, called att tonight, they said that's the only wireless modem they sell. So they are sending me another 2wire worthless wireless modem. We'll see but I'm sure it'll be messed up anyway given that the design is most likely the problem.
Posted on Dec 29, 2009
Using a router as a wireless repeater/bridge
Try out this lifehacker artical. I am copying the link to my evernote, so I can try it at home.
http://lifehacker.com/5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
Feb 28, 2012 | Computers & Internet
Forgot my wifi passcode and can't access with my iPad
If you forgot your passcode, about the only thing you can do is reset your router and reset it up after. To do this press and hold the reset button (or press it in with a pin) for about 5 seconds and let it go, your router will reboot and when it comes back online, the wifi will be open and unconfigured. You can then log onto the network and access the router config with http://192.168.1.1 (linksys and some others) or http://192.168.0.1 (dlink and some others) or http://192.168.1.254 or http://192.168.0.254 (2wire)
If you have a PC laptop that is already connected to the wireless you can recover the wireless password most cases with this tool: http://www.nirsoft.net/utils/wireless_key.html
Regards, Chris
Sep 04, 2011 | Linksys Computers & Internet
My iphone keeps dropping the "password" for my 2wire router. Then anytime I do something that requires the router to do some things it shows that Im NOT connect to my Wi-Fi in my house. How...
first check for any computer that is connected to you modem.
try to access your modem gui or software
since you have a 2wire modem go to the wireless setting page
then configure your wireless settings
you can call your isp for the correct wireless setting configuration
May 27, 2011 | 2wire (2701HG-B) Wireless Router
I need one
If you need a router, you can purchase one over the internet through multiple vending sites, your local big-box retailer (like Wal-Mart, K-Mart, Staples, Best Buy, Fry's, Officemax, Target), your ISP (although usually at a ridiculous premium!), and some computer manufacturer sites (Like Dell)
Price the features- good brands include Linksys, Dlink, Netgear, and Belkin- although there are other brands. Ease of setup favors Dlink and Belkin, robustness of features favors Linksys and Netgear. Personally, I use Belkin.
Oct 02, 2010 | Computers & Internet
I like pulsar and i want to buy pulsar 150 bt my friends said that its engine create noise after few months and not suitable for a marketing executive as maintainace is costly in compare to cbz or apache i...
If at all possible, buy a Honda, Yamaha, Kawasaki or Suzuki and away away from Bajaj. The Japanese bikes are MUCH better. Bajaj bikes are not dependable and repair parts are hard to find.
Sep 11, 2010 | Bajaj Pulsar 150 Motorcycles
I have a sony handycam dcr hc36 and I also possess ppackage cd and which has been installed in my hp laptop -window vista when I am connecting my camera to laptop for streaming, there is no response,...
Connect your camera to your PC by means of FireWire cable,that is the solution.
-Stable,trouble free data transfer during video capture.
-Video transferred at its maximum resolution 720*576 pixels or something like that compared to 340*240 via USB transfer.
-100% supported by any video editing program,even the simplest Window Movie Maker.In other words,forget Sony's software - use something else that wouldn't run you.
Of course,those Firewire cable&card might be not very globally available like USB device.But still easy to find and relatively cheap to buy anyway.
Aug 07, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
I need picture package software
Forget those software.
Even windows movie maker can do as good job (if not better than) those pic.package thing.But you need to use Firewire cable&card to do the job.Firewire connection is also far superior than USB cable connection,too.
Aug 06, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Can i use the 2wire 1000 modem only as a HUB or Switch?
The 2wire Modem acts as a router too. Some Models have wireless connections. You can use hubs and switches along with.
Jul 30, 2009 | 2wire Computers & Internet
2wire 2700HG-B Router (2700HGB) Logo
18,796 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
