Question about Zebra Stripe S600 Thermal Label Printer
Zebra S600 will not do anything???
We have a Zebra S600 label printer here, one of the girls had run out of labels so she replaced them, first of all it started to print but the ribbon wasnt taking up the ribbon. But now the printer will not do anything, the printhead light just keeps flashing. I have on numerous occasions tried to put it back to factory settings, I have tried every trick in the book. We do not run zebra software it runs with another piece of software just for us to be able to get labels. Anyone have any ideas??
Thanks in advance
Emma
  • 13 Answers
Emma, I can assist but this is slightly technical. The issue more than likely is the print head sensor flag is out of position. If you have the print head all the way down & purple toggle in the locked position but the print head light still flashed then more than likely it is the flag that came loose. To correct it means you have to remove the left side cover where the logic board is. Make sure to remove power cord & all communication cables & connectors prior to cover removal for your safety. After the cover is removed you will see the logic board. On the upper right corner area will be a SCREW with a black "L" shaped piece of plastic, this is the flag. At this point make sure the print head is down & locked. Place the flag in the horizontal position, which should be between the sensor positions, While holding retighten the screw. Once tight open & close the print head to see the flag move up & down between the sensors. Place the cover back on but put 1 screw in only so you can test. If all works put the rest of the screws in & continue to work. If not then update this & I will get back with you.
Posted on Feb 11, 2009
Zebra s600 prints on label and feeds 3 blanks
it must be wrong label configuration or problem with gap sensor.
You can follow this step by step zebra designer ;
Zebra Designer Kurulumu ve Kullanm Teknik Barkod Etiket
Jul 02, 2014 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
May 18, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
HOW TO REPLACE LABELS
Look at this I think it will help.
Jan 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
612 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
