Question about Hotpoint WMM65 Front Load Washer
Machine Pump has stopped working on Hotpoint WMA64
My machine has stopped draining the water away. We have taken apart and have managed to drain off most of the excess water, however, following a further spin cycle, it has become apparent that the pump is not removing the water from the machine. We have looked up parts but would like to know where we would find instructions, or whether it would be possible, for us to install a new pump ourselves.
  • emmafay Feb 13, 2009
    Hi Again,
    As your help was so good with our last problem and from looking at your expertise details, we thought we'd see whether you can help with another couple of problems. I will post these by a general query also so that we can give you some more positive feedback. If not your area, apologies for wasting your time.
    1. Whilst buying the new pump for our Hotpoint WMA64 washing machine, we bought a new door seal too as ours was mouldy and a little worn. Could you tell us how we go about changing the door seal?
    2. We need to fit a new door seal on our Seat Leon Cupra. Is this a job we could do ourselves and how would we go about it?
    Many Thanks again for your help!
    President:
  • 842 Answers
I believe that the hotpoint part number is 1603290, the price in the UK is about £25 (About $35?). the pump is fairly easy to replace as far as I can see (I don't know the exact machine, but I have looked at the part. The pump is held to the chassis by 2 philips screws. pipes in and out of the pump will be held on by either a screw up clamp or a spring clamp, both of which are easy to remove. Power is via a 2 wire plug in connector. If you are a ressonably practical person, you should have no problems.
A few things before you start:
  • TURN THE POWER OFF (And this means pull the plug out of the wall!)
  • Drain the machine as best as you can.
  • Have towels to mop up when you discover your best wasn't good enough.
  • Once you have removed the pump, dry up properly before you start work with the replacement
  • Always tip the machine BACKWARDS and away from the control panel so leaks don't wreck your electrics and change a $35 repair into a $200 repair.
  • Have a look before you buy the part. Decide if you are happy to go ahead and understand what you are doing.
Finally, just consider the question is it actually the pump? If you can hear the pump running, its probably not the pump. If you can see water coming out of the waste pipe when you put it in the sink, its certainly not the pump. Take a look at the information I wrote for someone else about clearing a blocked pump before you go to replace the pump (I have reprinted the whole article below). I would strongly advise you to carry out the checks below anyway, because they may have contributed to the pump's failure if you have got a dead pump. Doing the following will help preserve the new one.
The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
  • Chris Hall
    Chris Hall Feb 15, 2009
    Take a look at my article http://www.fixya.com/support/t1543617-do... for your washing machine door seal, that should give you the help you need.
    As far as the door seal on the car goes, they usually just pull off (But I don't know your car specifically of course!). You may have to ease the seal past a couple of plastics and some cars have a sill guard foot plate that runs over the top of the door seal, but these are usually clipped on or held in place by a couple of screws. It should be an easy DIY job. If you are unsure, I imagine that your local auto repair shop will charge you next to nothing to fit it if you talk nicely to a mechanic there and supply the part yourself.
SOURCE:
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
Water wont drain away when in its final spin,and i have have fitted a new drain pump
If you changed the drain pump I would check the following things:
1) Is the machine actually sending power to the pump to turn it on. You can check this by using a volt meter and with the machine open disconnect the power to the pump and place machine in drain and test to see if voltaqge is being sent to the pump
2) Check your lines and the drain itself. Any blockages could prevent draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Hotpoint Washing Machines
Pls my wma64 is not retaining water for washing, it releases water immediately the water goes into the machine. Pls what can i do ?
The most likely reason is that the drain valve is stuck open. If the unit is newer it can be caused by debris and might be cleared by repeatedly cycling the valve. If older the valve may have failed and will require a new one. Another less likely problem is the timer assembly that controls the valve.
Mar 05, 2011 | Hotpoint WMA64 Front Load Washer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
I thought my Hotpoint washing machine WMA6 had
you shouldnt be able to open door if there is water in it. sounds like your door interlock has burnt out and probably taken the main printed circuit board with it.
Oct 30, 2009 | Hotpoint WMA64 Front Load Washer
The washer has stopped emptying and spinning. The pump does not appear top be making any sounds either.It is a hotpoint aquarius
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Aug 20, 2009 | Hotpoint Washing Machines
Leaking machine
Could be caused by several reasons.
1- Overfilling, check water level .
2-Blockage in dispenser, or dispenser inlet hose to drum
3-Drawer not in properly.
4-M/c not draining properly, thus when it goes into spin, water could be thrown up by centrifugal force, and come out of the front of the drawer.Check filter.
5-Water pressure very high, forcing water out of drawer, adjust pressure.
Plz rate my soution.
Thanks.
Dec 30, 2008 | Hotpoint WMA64 Front Load Washer
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMM65 Front Load Washer Logo
235 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
