Question about Canon PIXMA MP780 All-In-One InkJet Printer
Cartridge Jammed The printer says 'Cartridge Jammed Press ok' when I press ok it says please wait and then goes back to the original message. The printer status says service error 6000, cancel printing and press ok. This still does not fix the problem
  • Anonymous Mar 16, 2014
    printer is saying cartridge jammed how do i fix this
  • 417 Answers
Try removing the print cartridge and then insert it again this should clear the problem.
Posted on Feb 09, 2009
SOURCE:
HP c6180 Won't print magenta dark or light
Regarding your question about the HP 02 Light Magenta/Dark Magenta printing issue (lack of print output), are you observing the error message(s): "R6025M, R6031M" and/or "INK SYSTEM HAS FAILED" with your HP Photosmart C6180 printer? Based on your problem description, this could be poor connectivity between the ink cartridge and the printer's PRINTHEAD or the PRINTHEAD has reached END-OF-LIFE. Unfortunately this particular printer writing system is now ~13 years old, and depending on your print volume, the PRINTHEAD may have suffered permanent electrical degradation*
Check chip condition, pictured here on our Inkjet411 support site (2nd picture circled in red): http://inkjet411.com/?page_id=1372
However to be sure, you may want to get a new HP 02 (OEM) ink cartridge to completely rule the refilled cartridge out of the equation as cause of failure. Otherwise, proceed to our suggested diagnostic steps below.
If one of the steps cannot be performed please go to the next one. If you do not have one of the buttons go to the next suggested solution.
Solution One
A. NON KEYPAD PRINTER MODELS: http://inkjet411.com/?page_id=2377
1. Get the unit into the "Support Menu" by following the steps below:
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release the "OK" button.
Display should say "Support" and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says "System Configuration Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. Retest the printer.
B. KEYPAD EQUIPPED PRINTER MODELS: http://inkjet411.com/?page_id=2391
Steps:
1. Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
Then
1.
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
C. - Press and release in sequence the "1", "2" and "3" buttons.
Screen should say "support" R0631M
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO XXXXX" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. Retest the printer.
Solution Two
(1) Open the printer and wait for the carriage to slide over
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Solution Three
If both solutions ones and two fail it means your waste ink absorber is full and needs to be replaced. The absorber is a small sponge like pad inside the machine underneath the ink cartridge cradle. It sits underneath the cradle when the cradle is all the way to the right inside the machine. To fix this problem the pad needs to be replaced - see video: https://www.youtube.com/watch?v=km3szjM49ZQ
Solution Four
If all the other solutions fail it means the permanent PRINTHEAD inside the machine has likely failed; unfortunately the PRINTHEAD is not replaceable in this printer model*
*The HP 02 ink series printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 6 ink cartridges and then firing the ink droplets onto the paper) - the HP 02 PRINTHEAD typically has a maximum life of approximately 40,000 pages (~15,000 page average). Unfortunately, the permanent PRINTHEAD is not replaceable. http://inkjet411.com/?page_id=2054
CAUTION: Be advised, the use of HP 02 compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD damage due to incompatible ink formulations. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 02 or HP 02XL original/genuine ink cartridges is only suggested!
HP 02/02XL Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=SGA692TUWTc
If, after performing the suggested procedures above, you still have not reached resolution please let us know. For any additional questions please contact us directly: [email protected]
If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
-Thank you
Inkjet411 Team Member
Aug 19, 2014 | Office Equipment & Supplies
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Menu".
it is now powered down and unplugged.
12. If the printer has already initialized, then go to the next step. If not, the printer
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Receiving error message: 0xc18a0001 error message on hp c8180 all-in-one printer. what can I do?
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If I've helped you, please vote! Thanks!
Dec 09, 2010 | HP Photosmart C8180 All-in-One InkJet...
I replaced the yellow cartridge and printed a picture. When I started to print another, it came up with Oxc18a0001 error. I've tried every thing I know. Help!!
If the error is still there, or reoccurs replace the unit
DON'T PERFORM THIS STEP MORE THAN ONCE
Nov 21, 2010 | HP Photosmart C5180 All-In-One InkJet...
Is it possible to disable the date chip on the ink cartridge? I have a HP8250 Photosmart printer, the yellow ink is outdated and I cannot even print a black and white document! I do not live near any...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Aug 21, 2010 | HP - HP Photosmart 8250 printer
I have just changed the ink in my printer and I have received an error message C18a0206. I can't locate this in my documentation. What is the problem?
PERFORM THE FOLLOWING STEPS:
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the right arrow button until the display says “System Configuration Menu”.
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
May 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Message 0xc05d1281 message is continually displayed. Have tried all the suggestions on website by other users. Possibly small piece of paper jammed as problem started once paper jammed. Can you tell me how...
Hi there 0xc05d1281 Problems
The "Ink System Failure" error is causes by air in the ink feed tubes.
I hope this helps, If so please rate our solution.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
You should be back up and running.
Click LINK= http://www.4all2sell.com/pdf/http://www.4all2sell.com/pdf/HP-photosmart-3300-3310-3310xi-3313-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Feb 16, 2010 | HP Photosmart 3310 Printer
Ink system has failed error Oxc 19a 0031
Are you experiencing the ink system failure on your printer? The error is caused by air getting in the ink tubes feeding the system. This is normally cause by refilled cartridges but can be caused by any cartridge that goes very low on ink and then tries to reload ink. This reset procedure does have to be performed with a full cartridge installed. The following reset procedure will correct the issue by purging the ink tubes and flushing any air trapped in them.
I hope this helps, If so pleae rate our solution
Nov 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
C8180 Error Oxc18a0001
Hi there
Solution 1:
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Solution 2:
Oct 15, 2009 | HP Photosmart C8180 InkJet Printer
Printer failure
try this
Solution 1:
Solution 2:
Jan 12, 2009 | HP Photosmart 8250 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
234 people viewed this question
Clive
Clive
old marine
old marine
Ekse
