Question about Pioneer Televison & Video
MODEL DVL 919...DVDS GET STUCK IN SEARCH MODE. I TRIED IN MY OFFICE DVD PLAYER & WORKS FINE...
  • michael_bloo Feb 09, 2009
    I'm not at home now, However, I tried that once & it didn't solve the problem
    Novelist:
  • 126 Answers
first of all try and clean the lens and head and after that clean it with the lens cleaner and it should work,try with the different cd's and dvd's not only with single dvd,it will work....good luck,pls rate the solution.....thanks
Posted on Feb 11, 2009
    Scholar:
  • 127 Answers
Welcome to fixya!
please try to clean your DVD player lens with a DVD lens cleaner disk.
let us know if it made difference. thanks.
Posted on Feb 09, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try a CD disc cleaner in the event that the lens is dusty. Additionally, you can try to open the unit and clean the inside. It would also help to clean/re-lubricate the mechanism. Or particular interest would be the worm gear and the slider spindle that moves the lens carriage assembly. A can of compressed air would also help in those hard to reach areas.
Good luck and thank you for using FixYa.
  • 679 Answers
Reset your DVD player.
unplug the unit for 10 minute and get back.
  • rockfixya
    rockfixya Feb 09, 2009
    To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down buttons at the same time until it says "Bye" on the display. When it shows the clock it is off - wait a few seconds then turn it back on - you should see the initial setup asking you to choose a language.
    Note: You may have to flip down part of the front panel to reveal the channel button.
    good luck..
Can I see DVDs from this DVD player on a smart TV?
try to find out what connections both have. See if you can put them together. look for the out on the DVD and in on the TV.
Next question, please put the device name(s) brand(s) and model(s) in the question.
Mar 21, 2015 | Sylvania DVL-700E DVD Player
Looking for a manual for the DVL-919. Running it though a Onkyo TX-NR807 AV receiver and it keeps defaulting to monochrome.
okay check electromaniacs.com for a free copy.or partstore.com to buy one which ever you choose.good luck
Feb 28, 2010 | Pioneer DVL-919 DVD Player
Dear Sir My Dvl 919 dvd player component output give black and white images no colour but SVHS have color images.Pls advise Erwin Koh
there are three wires associated with "component output" .. those have to be hooked up to component inputs on your TV .. not to the composite video input .. if you do hook up to composite you will get only a black and white picture .. make sure all three wires are connected correctly then select the proper input in your TV setup ..
Jan 27, 2010 | Televison & Video
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
Matshita uj850 dvd dual layer..
On DVD Player as well as Computer DVDs there are different zones search for unlock code for your dvd play follow the instruction and it may work I have done this for my DVDs players connected to the TV as well as the computer ones
Jan 22, 2009 | Toshiba Satellite A135-S4527 Notebook
DVL-V888 has MECHA CPU message
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Aug 29, 2008 | Pioneer DVL-V888 DVD Player
Pioneer DVL-919 DVD door does not open
You can also try flipping the player upside down and shaking it a little. I bought a DVL 909 and when it arrived the tray wouldn't open. The seller told me to try that, and it actually worked. I wouldn't recommend shaking it quite so much as this video shows... but it does show that it can work.
Dec 14, 2007 | Pioneer DVL-919 DVD Player
DVD not recognised
the only solution is to change its firmware, NOT SO DIFFICULT. Or try buying a new one!! Patrick
Oct 26, 2006 | Pioneer DVL-909 DVD Player
Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Oct 23, 2006 | Zenith XBV442 DVD Player/VCR
Televison & Video Logo
27 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
