Question about Tecnik TKR6610 Bottom Freezer Refrigerator
Tecnik tkr6610 fridge not very cold
My Tecnik TKR6610 does not get very cold. As the back wall has a lot of condensation I suspect that it may be constantly defrosting. Does anybody have any suggestions as to how it can be fixed?
SOURCE: NEEDED MANUAL FOR TECNIK COOKER
I have a manual if you e mail me your address to monica230157@hotmail.com, I'll photocopy it and post it on to you.
Posted on Jan 05, 2009
amgm
  • 32 Answers
SOURCE: Tecnik TKC 1426 Kitchen range
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 22, 2009
SOURCE: instruction manual for Tecnik 9290 washing machine
i need intruction manual
Posted on Sep 06, 2009
SOURCE: I need the Manual for the Tecnik TKC 1285 Dual Fuel Kitchen
anyone still need the users manual for this, i have a copy and could scan and email it, drop me a line on probinson09@mac.com anyone ever changed any of the elements, my small oven grill element is warped and the fan element has stopped working, i have the parts but haven't attempted installing them yet
Posted on May 04, 2010
  • 228 Answers
SOURCE: tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Posted on Jun 05, 2010
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
SPARE PARTS TECNIK TKR601
I'm looking for an adjustment bar to balance the back legs of my fridge
Mar 01, 2013 | Tecnik Built Under Larder Compact...
I want to order a box for the fruit and vegetable for my fridge which is a "Tecnik" make and I am having difficulty locating the company. My fridge/freezer was installed by "Moben...
There are plenty of websites advertising refrigerator spare parts - all you have to do is search them with the model make and number of your fridge and they will tell you if they have the part and how much - simple really.
Tecnik is in Manchester - I think they have gone bust as a subsidiary company of a larger one,
tel 0161 7864295
Aug 06, 2011 | Tecnik TKR6610 Bottom Freezer Refrigerator
Fridge freezer installed 3 weeks ago and the top half of fridge back freezes. Dial is on 1 dot.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 02, 2010 | Tecnik TKR6610 Bottom Freezer Refrigerator
Tecnik TKC 1285 back-plate
don't know technic products but suspect you just need a bit of bruto force - back plates can be stuck in with crud that accumulates
Oct 07, 2008 | Tecnik TKC1285 Dual Fuel (Electric and...
Fridge
hi,can i know the model of your fridge ? thanks
edgz
Jan 31, 2008 | Tecnik TKR6610 Bottom Freezer Refrigerator
TECNIK TOP STOVE
although not with a Tecnik, I have found that if you unplug the stove from the wall and let it "set" for a day or so, it gets out of this repeat clicking mode. Sometimes doing it twice.
Jan 09, 2008 | Tecnik TKC1285 Dual Fuel (Electric and...
Tecnik TKR6610 Bottom Freezer Refrigerator Logo
100 people viewed this question
Top Tecnik Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
ray gallant
Are you a Tecnik Refrigerator Expert? Answer questions, earn points and help others
