Question about Acer TravelMate 240 Notebook
I spilt coffee on my laptop. The keyboard is not working
The keyboard was cleaned and blown but on fixing it back it has not worked at all. I've fixed a USB and it has worked but the touchpad is not working. do i buy a new keyboard ? Is the touch pad spoilt/
My machine is an Acer aspire 5630
  • marthur Mar 31, 2009
    After spilling coffee on the keyboard of laptop the keyboard stopped working. I also connected a usb keyboard which worked ok. I replaced the original key board with a new one but that would not work.
    Scholar:
  • 127 Answers
Usually laptop keyboard and touch pad have a protecting cover for situations like this, but would depends on how much, how far and how long the liquid stayed on the keyboard and pads surface.
one thing to check though.
remove again the keyboard of the book and check the keyboard cable going to the board if its tightly fix, same with all other connectors.
if still the same problem...then the keyboard is fried.
Posted on Feb 09, 2009
Why doesn't keyboard work?
Electronics dont do very well when they get wet. i would take it apart and dry it out with a hair dryer. All you have to do is take the screws out on the back and pop the 2 halves apart. You do have to be careful. once it;s apart you will see why it was;nt working. good luck
Aug 29, 2015 | ZAGG Folio Keyboard
How to get the keyboard to work properly after spilling juice on it?
It is virtually impossible to clean or fixed a keyboard that has liquid spill on it. You need to replace the keyboard.
Replacement keyboard for your model laptop maybe available from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jul 16, 2012 | Dell Mini Computers & Internet
I spilt milk on my samsung laptop I shut the power off and wondering what is the best way to dry it
Most likely when the laptop dries out the milk residue will stop the keyboard keys from working properly. Depending upon how much milk has been spilt the milk may have penetrated to the motherboard and caused more damage.
Place the laptop in a warm area for several days.
If the laptop boots up properly but the some of keyboard keys don't work then a replacement keyboard may fix your problem.
Keyboard replacement maybe available from this WEB site.
Jun 24, 2012 | Computers & Internet
How do I strip key board on my laptop to clean spilt coffee
http://www.laptop-repair.info/laptop_keyboard_repair.html
the steps to remove the keyboard is to remove the hinges cover first ..than the screws holding the keyboard in place (under the hinges cover) ..than slide it an inch forward (toward the screen ) ..and after that lift it up ...remove the ribbon from the plug ...and this is all ..replace it if you have the possibility ..or ..remove all buttons ...and clean it up ...and dry it well before replace it and see if it work s..If the damage is permanent you need a new one and the procedure is just the reverse..
http://www.youtube.com/watch?v=_IN1RKtiFC8
Nov 29, 2011 | Samsung R519-53S Notebook
Keyboard not working. spilt coffee. how do i fix? LG LW60
Take it to an authorised service centre dont try over it by your self. Keyboard may require replacement.
Sep 15, 2011 | LG Computers & Internet
My GATEWAY pc laptop keyboad letter WEOPB BACKSPACE and #0 dont work.im now using on-screen keyboard.what shall i do.please advice.tnx
Seems like you have spilt liquid on the keyboard?
the liquid causes connections between the circuit board in keyboard which causes the keys to not work properly.
u can try take off the keys and get to keyboard, you might be able to clean it with isopropyl alchohol and a cotton bud to fix it.
if you cant get the keyboard out then there is nothing you can do!
Apr 07, 2011 | Computers & Internet
I need help fixing my sisters with my sisters laptop enter button
You're going to have to replace the keyboard... The Liquid has burned out the contact pad on the Enter button..
It could have as well ...reached the motherboard .. you should have it looked at, it will cause further damage.....
If Left On Motherboard... It Will Blow Capacitors And IC Chips, It eats away at the Solder...
Nov 28, 2009 | Samsung NC10-14GW Notebook
Error code 301
The IBM error 301 POST code means the keyboard is not responding correctly.
You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
You could have a faulty keyboard controller.
You may have a faulty keyboard which may had some fluid spilt on the keys.
Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Jul 12, 2009 | IBM ThinkPad 600X Notebook
Tea spilt on Laptop
If you can put up with the sticky keys and they still work then it is OK.
Otherwise you need to replace the keyboard.
Mar 01, 2009 | Acer Aspire 5735 Notebook
How do i clean a laptop keyboard
Hey,
its not a easy task.
I think you need to take it completely apart to get inside, the coffee most likely got inside the keyboard and is causing the problem.
all the keys need to come off, then look at it and see if you take take it apart, it might be glued together.
Not a easy fix.
You need to get inside to clean it, but in the process you might make it useless, and then how to get it back together.
I feel you will do better with a brand new keyboard.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Acer Aspire 4520-5582 Notebook
Acer TravelMate 240 Notebook Logo
395 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
