Question about HP LaserJet 4345mfp Printer
CONTROL PANEL BLOCKED LJ4345
I have a laserjet 4345. the control panel blocked after 5 min, and we have to reboot the printer to get it back.
i heard that a firware upadte will fix the problem, but is there anything else i can do?
thanks
  • gdesaintjust Mar 09, 2009
    thanks it works now perfectly
  • 24 Answers
Friend,
Yes, there's a firmware that should fix this. It can be found HERE:
Hopefully this will do the trick.
//Al
Posted on Mar 08, 2009
Hp LaserJet 1020 Not printing in Windows 7 Enterprise N.
Is your computer recognizing it? Try opening your Control Panel in Windows, find Devises and Printers and see if its listed. If not disconnect it from computer, then reboot. Hook it back up again, reboot your computer and see if Windows finds it. Also check to see if the printer is set as default printer. If not set it as such. Try it again.
Sep 20, 2014 | HP LaserJet 1020 Printer
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
When I try to print its said the printer if offline
The reason behind this is:
1. Either the printer is turned OFF
or
2. Computer is unable to detect the printer.
If the computer is unable to detect the printer, follow the below steps:
1. Disconnect the printer from the computer and turn it OFF.
2. Remove the printer drivers from the 'add/remove" wizard.
3. Delete the printer from the control panel.
1. Open control panel.
2. Select "Printers" icon and doubble click on it.
3. Select the printer and press delete key.
or
Right click on the selected printer and choose "remove device" option.
( Note: Incase of Vista an win 7, you can find the installed printer in "Devices and Printer" icon on the control panel.)
4. uninstall the USB printing drivers if any from the device manager.
- Press windows key + r
- type "devmgmt.msc"
- Under USB controller
-right click on "USB composite devices/USB printing" and select "uninstall" option.
5. Reboot the computer.
6. After reboot, connect the printer to the computer and install the drivers for the printer.
Jan 07, 2011 | HP LaserJet 2840 Printer
The scanner on our HP Laserjet 6040 MFP is blocked. How can I unlock it?
Follow steps given below:
In control panel click at printers and faxes,click at properties menu and select hardware component.
Click at the scroll bar given at the end and select use this device.
Your blocked printer will working.
Sep 23, 2010 | Office Equipment & Supplies
Hp laserjet 8150 black blocks lcd display
If the printer isn't intializing then you may have a formatter issue. Try reseating the the formatter in the back of the printer. There is two thumb screws that hold it in place. If the printer is booting up and you can still print to it but you just can't read the control panel then the problem is with the control panel.
May 17, 2010 | HP LaserJet 8150n Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
HP 4345. Need to reset the Maintenance kit error. How do I get into ther Service Mode and how do I reset it? Thanks!
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Jun 08, 2009 | HP LaserJet 4345mfp Printer
Hp 4345 mpf - offline
Friend,
If the printer's display just says "Offline" yuo should push the Sleep button on the front panel and you're done. If the message occurs in the printer driver instead, you could try to disable BiDirectional support in the driver.
//Al
Mar 08, 2009 | HP LaserJet 4345mfp Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
HP LaserJet 4345mfp Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
