Question about Compaq Presario Notebook
Still needed solution of problem
Hello sir,
Que:-1 I want to use DMA Transfer mode instead of PIO Mode in my system. The problem is that my system is not taking Primary IDE Channel in which current trasfer mode is in Ultra DMA Mode 5. While system is taking Secondary IDE Channel in which current transfer mode is in PIO Mode. Few months ago it was working in Primary IDE channel and Transfer Mode was Ultra DMA Mode 5, But I Don't Know how and when it Switches to Secondary IDE Channel with PIO Mode.
Now Please tell me how can i bring my system back in Primary IDE channel with Ultra DMA Mode 5.
Company Name of my lapotop:- COMPAQ Product Name:- Presario C300 Product Number:- RE022PA#ACJ Serial Number:- CND6401MRF
Operating System:- Microsoft window xp Proeessional.
Service Pack - 2.0
BIOS Version : F.15
Device Type:- IDE ATA/ ATAPI Controllers.
    Problem Solver:
  • 15 Answers
This condition is caused by spyware,hard drive problems. First create a restore point, then run this script http://winhlp.com/tools/resetdma.vbs reboot and should do the trick. After XP tried to access the hard drive without success for any reason there is a register counter that downgrades the speed of the hard drive to PIO. Good Luck!
Posted on Feb 09, 2009
  • Compaq Master
  • 32,281 Answers
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Why do dvd burn so slow it take a hour for one movie
It takes awhile because the USB interface in between the drive and your computer is a good deal slower than the interface an INTERNAL drive has connected with the motherboard, especially if you're using USB 1.0 interface. Don't worry, they are implementing USB 3.0 right now in new computers and in a few years Intel will have an interface called "light peak" which will be much faster because it is fiber optic instead of electrical.
For now you'll just have to live with it, or replace your motherboard with one that has USB 3.0.
Mar 14, 2011 | Memorex Products - External DVD Recorder,...
Tip
If your older PC has lost some zip -- An easy thing to check & fix.
After a while, usually several years, your hard disks wear. As this happens the disks will have errors. Windows keeps track of these errors and if they grow too numerous Widows will take actions designed to reduce the possibility of a catastrophic event. One thing it will do is change the method it uses to access the hard disk. It will change from DMA mode to PIO mode and slow you way down. This tip will restore DMA mode so you can get a little more use out of your aging system. You won't need any disks or special software, but you will have to reboot twice.
In Windows get to Device Manager.
One way to get there is click Start, right click My Computer, select Properties, click Hardware tab, click Device Manager button.
In Device Manager, press the + next to IDE ATA/ATAPI controllers.
It should look something like this:
Double click Primary IDE Channel. Click the Advanced Settings tab. If there is no Advanced Settings tab then this tip will not help you, but check the other possibilities (Secondary IDE Channel, other controllers) the same way.
Check to see if the Current Transfer Mode says PIO. PIO stands for Programmed Input Output. It is the slowest mode of disk access. If the Current Transfer Mode is something with DMA (Direct Memory Access), then this tip will not help you as this is the preferred mode.
Check to see if the DMA if available is selected in the Transfer Mode box. If not, select it.
At this point you have determined that you are using PIO mode for one or some of the IDE Controllers and that you have selected DMA in the Transfer Mode. The next thing is to make Windows load the correct DMA driver.
Click the Driver tab.
Click the Uninstall button. Click the OK button. Do this for all IDE Controllers that show PIO mode.
Windows will ask if you want to reboot. Let it happen. Windows will reboot, load the DMA drivers, and tell you it has to reboot again. Let it happen.
Now the DMA drivers should have been installed and some of the snap should return to your PC.
Eventually, Windows will revert back to PIO mode. Your disk is wearing out. Get a new one!
on Sep 21, 2010 | Computers & Internet
Video playback stutters is choppy when the video plays it stops and stutters on a frame. it will play for a few seconds then stutter.
I had a problem similar to this and eventually traced it to the wrong mode setting on the DVD drive's transfer mode.
To check the setting, open Device Manager and then double click on the IDE controllers item. Double click on IDE channel (if there's more than one you'll need to check each one) and then select the Advanced Settings tab. On this tab should be up to two devices and each should show under "Current Transfer Mode" soemthing including the word "DMA".
If any device shows "PIO", then this is probably the problem.
If you Google "PIO versus DMA", one of the top results has a really good article on why this happens and how to force Windows to revert to DMA.
Sep 23, 2009 | Acer Aspire 3000 Notebook
How do you change dma for xp to default
1.
Open Device Manager.
2.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
3.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
4.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
• Change the selection from "DMA if available" to PIO only, and click OK.
• Then repeat the steps above to change the selection to DMA if Available.
Sep 23, 2009 | Microsoft Windows XP Home Edition
Trying to set DVD-R/W to DMA mode, currently stuck in PIO
you are trying which is not possible. all optical drives work in PIO mode ... hard disk typically run in DMA mode which is bypassing cpu to access memory directly without calling daddy CPU.... though i am amazed who offered you registry fix for this.
Aug 06, 2009 | Acer Aspire 9410-4317 Notebook
DMA
You can download a software fix for it:
http://winhlp.com/node/10
It's called resetdma.vbs ,download it and then install it.
The site also has some tips if the software doesn't help you.
May 14, 2009 | Compaq Presario Notebook
Need Solution of a problem
try this. go to BIOS, from your main page choice sata1 and press enter then press DMA MODE and chanege to UDMA5 press enter F10 save and exit
Feb 07, 2009 | Compaq Presario Notebook
Problem with LITE-ON DVDRW SHW-160P6S ATA Device
There is a whole bunch of helpful stuff at http://www.tomshardware.com/forum/196090-32-lite-dvdrw-160p6s-burning-problems
Seems that the drive may overheat, and will need replacement if in warranty. Some advice given: get another type drive. Also, check the device manager and make sure it's running in DMA mode and not PIO mode. If you have an nForceX mobo and using the SW IDE driver, reinstall with the normal IDE driver and try again. In device manager, check under IDE ATA/ATAPI controllers. Right-click and select properties on the IDE Channel your DVD recorder is attached to. Transfer mode should be set to "DMA if available". Current transfer mode should be "Ultra DMA Mode 4". If it says Mode 2: Your drive may be experiencing problems which are causing windows to drop its speed. There is a support article with a fix. To surmize:
After the Windows IDE/ATAPI Port driver (Atapi.sys) receives a cumulative total of six time-out or cyclical redundancy check (CRC) errors, the driver reduces the communications speed (the transfer mode) from the highest Direct Memory Access (DMA) mode to lower DMA modes in steps. If the driver continues to receive time-out or CRC errors, the driver eventually reduces the transfer mode to the slowest mode (PIO mode).
If you have dropped from DMA mode 4 to DMA mode 2, and you have a spare ribbon cable, you may want to try swapping it out. Also, if there is another device on the same channel as the DVD drive, try disconnecting it.
Mar 12, 2008 | Computers & Internet
Audio and video track are not in sync
I guess that your CDROM Device doesn't have DMA (Direct Memory Access) enabled.
From the Microsoft Knowledge Base Article:
To enable DMA mode using the Device Manager
1.
2.
3.
4.
Oct 14, 2007 | Computers & Internet
Compaq Presario Notebook Logo
192 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
