Question about HP Pavilion dv2840se PC Notebook
Bluetooth device software
Good day. i have problem with my laptop, in the desktop always pop up = "need to install bluetooth peripheral device software", i can receive files thru other bluetooth device, but i cannot send to them. my bkue tooth is enabled, but in my device manager, it says that there is no device software installed, what will i do? below is the report from window, hope it could help.
Problem caused by SyncML This problem was caused by a compatibility issue between this version of Windows and SyncML.
This product is usually distributed by the company that manufactured your device or computer.
Note
If you bought SyncML from a retailer and installed it yourself, you will need to contact its manufacturer.
Recommendation
To find out if a solution or an updated version of SyncML is available, go online to your computer manufacturer’s website:
Broadcom Corporation Hello,
The problem was “kind of” solved. Before, I was getting the “Found New Hardware” message twice (It would reappear after I would cancel it). Now it is appearing only once.
I thought that if I ran through those steps once again, uninstalling the old driver and installing the new, perhaps I could have gone down from one "Found New Hardware" message to zero messages, but it didn't work.
Do you have any other suggestions?
Thank you,
JMT
What do i need to do to install a bluetooth peripheral device on my laptop ?
Go to any local computer store or ebay.com and get yourself a USB bluetooth dongle. Load-up the software, pair your phone or other bluetooth device with your computer and you're good to go!
Dec 04, 2014 | Nokia Cell Phones
Bluetooth perephal device problem on dell inspirion
If you want to connect a Bluetooth peripheral device to a computer, you may need to download a new driver to support it.
There are two approaches to this:
If your Bluetooth device came with a driver on a disc, you can install the driver directly from the disc.
Otherwise, simply connect your computer to the Internet and connect your Bluetooth device to your computer, then wait for Windows to install any required drivers automatically.
You may receive this message when you connect your Bluetooth device to your computer: "Windows needs to install driver software for your Bluetooth peripheral device."
Bluetooth peripheral device driver downloads are easy to locate via any search engine.
Open the CD-ROM drive on the computer and insert the driver disc that shipped with the Bluetooth device.
Wait for a moment to see if the software auto-launches, as most modern software discs do.
If the program does not launch automatically, double-click the "My Computer" icon and then double-click the "CD-ROM drive" icon.
If this does not launch the software but instead opens a file folder, look for a .exe file such as "setup.exe" or "run.exe" and double-click that.
You're looking for a Bluetooth peripheral device driver.
Follow the on-screen prompts, once the software launches, to install the Bluetooth peripheral device drivers on the disc. You may be prompted to restart your computer at the end of the process.
Letting Windows Install the Driver
Make sure Windows is up to date, as most Bluetooth drivers are included in Windows Service Pack updates.
To do this, make sure your computer is connected to the Internet, then click the "Start" button in Windows and select "Windows Update" from the program list.
This will launch an Internet Explorer window. Click the "Find Updates" button in the window and wait for Microsoft to search for available updates.
If it recommends any high priority updates, follow the on-screen prompts to install them.
Connect the Bluetooth device to the computer.
There are three ways to do this.
If you have an internal Bluetooth receiver in your computer, just make sure the receiver and your Bluetooth device are turned on and put your device within range of the computer.
If you have a USB Bluetooth receiver, plug it into an available USB port on the computer; then turn on the Bluetooth device and put it within range of the computer.
If you have another type of auxiliary cable, you may also be able to use it to connect your Bluetooth device to the computer without using a Bluetooth connection.
Watch the system tray in the bottom right corner of Windows.
You should see a notification that Windows has detected a Bluetooth device, followed by another notification that the device has been installed properly.
The installation it is referring to is that of the driver. If this does not work as expected, proceed to the next step.
Click the "Start" button in Windows, then click "Control Panel." Launch "Device Manager."
Expand the "Bluetooth Devices" entry in the Device Manager by clicking the plus sign next to it.
Find your Bluetooth device listed under this heading, right-click it and select "Update driver" from the list of options.
Wait as Windows automatically finds and configures any missing Bluetooth peripheral device driver downloads.
Hope this helps
Nov 06, 2012 | Dell Inspiron 15R 5520 USB Docking Station...
How to connect bluetooth to my computer
If you have a laptop you have inbuilt application that helps connect laptop with other Bluetooth devices. If you are using a desktop there are many USB-based Bluetooth adapters available that will let you connect Bluetooth peripherals to your PC.
Sep 04, 2012 | Acer Aspire One D255E13438 Netbook
Not having bluetooth peripheral device drivers problem encountering when i start my bluetooth
~To download the manufacturers and therefore the correct drivers or specific software;
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the www.hp.com web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Feb 22, 2011 | HP SMARTBUY 6735S AMD SEMPRON SI-40 2.0...
Bluetooth peripheral device driver pop ups this problem has caused difficulties to send and receive files from bluetooth devices. fix bluetooth peripheral device driver download to solve the problem. I use...
Try to search for the correct acer bluetooth peripheral device driver from driversdownloadhub.com. There's a free driver search tool you can use as well as a list of manufacturers to get the one compatible to your OS.
Sep 08, 2010 | Acer Aspire 5610-4648 Notebook
How can i connect my nokia n70 mobile to desktop via bluetooth.plz tell me what to install the software for that.write now im with windows xp2.plz help me.i doesn't have any software regarding...
Dear Goutam,
Welcome to Fixya Support.
Generally every bluetooth device comes with driver CD.Some bluetooth drivers may preinstalled or inbuilt in windows XP with plug and play support.If bluetooth device drivers not present in windows, you have to install driver manually from CD, supplied along with your bluetooth device.
After Inserting bluetooth it pop up a message"New Hardware found",if drivers are inbuilt, operating system directly installs driver for your bluetooth device.
After Installation Go to control panel of your PC click on bluetooth icon,then click on search for active devices, if your mobile bluetooth is on pc will show your mobile name,then you have to pair your pc and mobile by supplying same pass key on both devices. So it completes pairing. Now you can share files between PC and mobile.
After installing bluetooth driver you can install Nokia PC Suit software for better management of your mobile content.
I think it solves your problem
If you have any difficulty leave a comment,we were happy to assist you.
Have a Nice Day!
Mar 27, 2010 | Computers & Internet
BLUETOOTH SOFTWARE FOR YOUR PERIPHERAL DEVICE
i want install my bluetooth peripheral device can yu help me
Sep 28, 2009 | HP Compaq 6710b Notebook
Bluetooth installed but keep asking for other peripheral device
Just install Laptop updater software as this problem seems to like that you are using the lower version of bluetooth driver. just go through the below link and download the updater. and after that connect the laptop to internet it will automatically installed all drivers.
http://downloads.drivershq.com/DriverDetective/RevenueWire/DriverDetective.exe?bcsi_scan_AEE3809AEBD0CAC9=1
May 02, 2009 | Computers & Internet
Bluetooth Peripheral Device error message I have a Sony VGN-FZ290 Laptop installed blutooth device is - ALPS UGPZ9 BCM2046 error - BTHENUM/{00005601-0000-1000-8000-0002ee000001}
Just disable the security software of your computer then try to pair again the devices and that should solve the problem....
Don't forget to rate the solution FIXYA thank you..........
Nov 01, 2008 | Computers & Internet
Not sure whether the Operating System in your Notebook is Vista or XP.
I am providing you the steps which can be performed in both windows XP and Vista one after the other. Try these steps according to the Operating System you have installed in your notebook :
Uninstalling and rienstalling Bluetooth Hardware drivers from your Notebook in Vista :
Click on the Start Menu and type Device Manager in the search field. Click on the Device manager link in the results.
The Device Manager opens in a seperate window.
In this, click on the [+] mark next to Bluetooth Radios to expand the tree.
Right click on any device which states 'HP Integrated Module with Bluetooth' and select Uninstall.
Restart the notebook once this process is done.
Cancell ro close any window which states New Hardware found.
Download the Bluetooth hardware drivers for Vista from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38167.exe
Save the file in the Notebook and double click once it is saved to install the drivers.
Uninstalling and rienstalling Bluetooth Hardware drivers from your Notebook in XP :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Now click on the [+] mark next to Bluetooth Radios to expand the tree.
Download the Bluetooth hardware drivers for XP from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32315.exe
Additionally, perform Windows Update so that any updates available from Microsoft for that particular hardware device will be installed.
Hope this helps...
Aug 14, 2008 | HP Compaq Presario V6000T Notebook
HP Pavilion dv2840se  PC Notebook Logo
196 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
