Question about Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the batteries within 3 hours with them turned off. Both units operate as they are designed too,when turned on however the circuits overheat. Regards, Peter (Nightjar) Posted by ismaelj on Feb 09, 2009 Hi I have 2 of these Rino with exact same problem. Can anyone say if they have had them fixed and if so what was the problem. I am in Australia and they are not sold or repaired here. I have looked at them but because both are the same and the SMD markings on the IC's seem to be unavailable I have no way of checking for the fault. Any help would be appreciated as the units are unusable at the moment. Please email me at ij@minelabmods.net if you have a solution or a circuit diagram:) Regards Ismael
  • 3 more comments
  • Peter Rob Feb 09, 2009
    I have the manual it is not a set up problem.
    It is a technical problem with the electronics.
    The Rino's are over heating and discharging the batteries with units turned off.
    Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours with the units turned off.
    They both work as designed when activated however they still get hot and the batteries have a short life.
    Going to be a long night, we do not have a SERVICE facility here in Australia.
    I am trying to establish whether the other owners of these units who are experiencing the same problem have been able to have their units repaired and how.
    It is not the batteries or the charger.
    Have tried a range of batteries, NiMH, Alkaline.
    If the top battery of the three is removed the remaining 2 batteries still cause the units to over heat and flatten these two batteries.
    DOES anyone have a detailed circuit diagram, detailing the components....
  • Peter Rob Feb 10, 2009
    Of course we have tried the menu select for battery types with no change. It seems that either an IC has gone down or a problem with the regulation. When batteries are put into the units with them off the current drain is 95mA. The batteries would not last 20 minutes and the unit (and a few IC's) gets very hot. Thanks but still no solution.
  • 19,396 Answers
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Posted on Feb 12, 2009
    Master:
  • 413 Answers
We used to use the rinos here where i work and when they broke i know we just replaced them with garmins or trimble junos. I do not know of any way to pull fault codes but i think it would be more worth it to buy new equipment.
The best thing i can recommend is to try to clean the unit out and if they are under warranty then return them.
Posted on Feb 11, 2009
  • 350 Answers
Dear nightjar, 5:50 AM 2/9/2009
I found the Owners' Manual for a GARMIN RINO 110 @
http://www8.garmin.com/manuals/Rino110_OwnersManual.pdf
On page 70 it says....
To change the battery type:
1. Use the "Thumb Stick" to highlight the "Battery Type" field and then press In.
2. Then use the "Thumb Stick" to select the desired option and press In.
Have you done this? If not it may be your problem!
Circuit Diagram Not Found!
Self Repair @ http://www.electronicrepairguide.com/
Parts @ http://www.partstore.com
Capacitors @ http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&WT.medium=cpc&WT.campaign=1045&site=US&WT.term=capacitors&keywords=capacitors&WT.content=text&WT.source=google&cshift_ck=1200880254cs502597329&WT.srch=1
Thermal Resistors @ http://www.milwaukeeresistor.com/?gclid=CMrojf7KyZgCFQETGgodr0zd0g
Other Sites You May Be Interested In!
http://pinouts.ru/GPS/rino-gps_pinout.shtml
http://www.springerlink.com/content/j351g666613p5853/
http://www.teardown.com/AllReports/product.aspx?reportid=571
Hope This Is Helpful!
jack
Garmin Rino 110
Posted by nightjar - f2f7cfb.jpgPlease Rate This!
Posted on Feb 09, 2009
    Brigadier General:
  • 3,614 Answers
Have you try to use a desktop charger.? or have you test the battery pack, better to use a new battery pack. the problem could only be there.
For further assistance, let me know
micro
  • micromaster
    micromaster Feb 09, 2009
    did you already reassemble or open the unit..?
  • 679 Answers
Please clarify your problem.
Thanks
  • rockfixya
    rockfixya Feb 09, 2009
    the battery has worn off due to which it gets heated up, try replacing the battery, it will help for sure.
    thanks
  • 495 Answers
  • Manoj Rout
    Manoj Rout Feb 09, 2009
    Contact your nearest service provider coz this problem may lead to serious devices damages. As device is overheating it means that you need to check for circuits being overheated. I think the best idea would be to contact your service center.
  • Manoj Rout
    Visit this site to register your device and serviced.
    http://www.garmin.com/garmin/cms/site/us
Where is the plugin on the rino 650 garmin
You need to use the AC adapter or specific vehicle charging cable to charge the rino series. They plug into a different port on the unit.
Jul 21, 2014 | Garmin GPS
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
My rino 110 will not stay on in cold weather, it will turn on but then turn right back off again. What can be done?
Batteries do not fuction well in cold weather. Use a better battery like the lithum or warm up the battery by rubbing back and forth on your pants both sides pos and neg.
-david
Nov 07, 2010 | Garmin Rino 110 GPS Receiver
Rino 110 will not aquire satilite signals.
To have a signal you have to go out in an apartment may not work
Apr 03, 2010 | Garmin Rino 110 (14 Channels) 2-Way Radio
Unit will not stay on. With new batteries installed, the unit turns on while power button is held down. It immediately turns off when power button is released. The batteries have never lasted long.
If using rechargeable batteries, your batteries are not getting charged. Check your charger, battery contacts and batteries. Clean contacts with a pencil eraser.
If using alkaline batteries, check placement of the batteries to be certain they are in the correct way, and also, clean the battery contacts.
Sep 07, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Batteries drain in and hour
You have a short circuit in your radio. Our Motorola's do this occasionally We can't fix them in house, the defective part is a surface mount device, we send them back to the factory where they replace the entire mother board.
Rino 110 stuck in one mode
There was a change to the WAAS satelite protocols. There is a new software download to fix the problem. The link is: http://www8.garmin.com/software/WebUpdater_241.exe
Jun 09, 2008 | Garmin Rino 110 (14 Channels) 2-Way Radio
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Sep 20, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 110 (14 Channels) 2-Way Radio Logo
848 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
