Question about Panasonic Lands Phones
I have panasonic kx-a145em phones with no instructions!
The ringer stops after 4 rings which means we never get to answer it before it goes to message.
Also need to set a personal answerphone message for it but can't work out how to do so.
Can anyone help??
Thanks
SOURCE: my Panasonic KX-TG2361JXB cordless phone answering
I NEED MASTER PASSWORD OD CORDLES PANASONIC..KX-TG2361JXB
Posted on Jun 05, 2010
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    SOURCE: Can't change ring tone on Panasonic KX-TCA175
    I had the same problem. I was advised by Panasonic support that the PBX system needed a firmware upgrade to solve the issue. (still waiting for technician to do this...)
    Posted on Jul 28, 2010
    I have a KX-T7433 and would like to change the number of rings before it goes to voice mail. It is currently set at 4 rings and would like to change it to 6
    The KX-T7433 isn't an answering machine. If the voicemails are going to an answering machine you have on the phone line, consult its manual. If the voicemails are going on to your telephone service provider's system, look for instructions in the phonebook, or contact the provider.
    If you need a KX-T7433 manual, you may download a copy at Panasonic KX T7433 Phone User Manuals Guides
    Oct 29, 2016 | Panasonic KX-T7433B Corded Phone
    Why did I suddenly lose my entire phonebook?
    [PDF]Operating Instructions - Support - Panasonic
    service.us.panasonic.com/.../KXTG6431-MUL.PDF
    PanasonicJul 15, 2009 - service offered by your service provider/telephone company. ...Expandable Digital Cordless Answering System .... KX-TG6431 series .... To prevent severe injury and loss of life/ .... you erase information such as phonebook ...... the ringer volume is turned off, ~ is displayed and the handset does not ring.
    Dec 25, 2015 | Panasonic Pansonic KX-TG6432M Cordless...
    Why doesnt my Panasonic cordless phone KX-TGH222AZ doe not ring it goes strait to message. People just hang up. I miss calls. How do I fix it?
    This is a simple question of the settings on the answering part of the phone setup. Go into the setup menu and change the 'number of rings before answering' to more than none. That or the ringer perhaps is muted. Make sure the ringer volume is not all the way down or off. If you need specific instructions on how to access the menus and change the settings either find the owners manual that came with the phone or go to panasonic.com and download a PDF user manual for it. If none of the settings change anything then the phone is probably broken and needs repair or replacement.
    Jan 26, 2015 | Panasonic Lands Phones
    How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
    Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
    4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
    Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
    Hi we have 4 Panasonic KX-T7730 phones in our office and 2 of them have stop ringing they are still receiving call but there is no tone to make you aware that its ringing!!
    When customers ask this question, it's usually because someone has turned off the ringer on the phone. A 77xx phone has a 3-position ringer switch on the left side of the phone. It's pretty easy to turn it to OFF.
    If you have somehow asked the question and the phone really doesn't ring, try swapping it with a working phone. If it still doen't ring, then it may be that the extension is not programmed to ring, but you didin't ask that question.
    Carl
    Jan 11, 2011 | Panasonic KX-T7730 Corded Phone
    How do I turn the ringer to on...Panasonic KX-T7630 located in my office.
    Either by pressing the Navigator Up arrow until the RING OFF goes away, or by programming the ICD group that rings the phones.
    One or the other.
    Carl
    Dec 21, 2010 | Panasonic KX-T7630 Corded Phone
    My kx t7730x doesnt have a ring but its receiving calls outside.
    I'm guessing this is connected to a TA series system.
    There is a ringer switch on the left side of the phone. Does it ring on intercom calls with the Auto Answer button not lit?
    The 2 things that control the ringer for outside calls is the ringer switch and programming. Intercom calls ringing is controlled by the switch, Auto Answer button, and programming. If the switch is set to medium or high and the phone doesn't ring, try it at another extension. If it still doesn't ring, it's broken, if it rings, then you have programming issues.
    Carl
    Sep 11, 2009 | Panasonic KX-T7730 Corded Phone
    Ringer is turned ,i need to know how to turn it on
    here is a download of your manual:
    [PDF] KX-TG2343File Format: PDF/Adobe Acrobat - View as HTML
    KX-TG2343. Pulse-or-tone dialing capability. The unit is Caller ID compatible. ...... Please use only a Panasonic KX-TCA60, KX-TCA86, KX-TCA88, ..... in accordance with the instructions and limitations specified in this manual. WARNING: ...
    service.us.panasonic.com/OPERMANPDF/KXTG2343.PDF
    May 23, 2009 | Panasonic KX-TG2343 Cordless Phone
    No ringer for incoming call
    I have seen this issue before and panasonic knows about it. I would contact them directly.
    Mar 30, 2008 | Panasonic KX-TG6052B Phone
    Phone ringer
    May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
    Lands Phones Logo
    340 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
