FixYa.com
Tags:
Dakota Rechargeable Watch
How do these things work?
By Duke - usenet poster
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
jessie25
jessie25 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I believe you're right, how lame that is indeed. I took their "Frank
Gehry's own script" claim at face value, my mistake.
True, but lame that they don't just use a matrix type display. It's not
that much more work and it falls in the non-recurring expense class
anyway. Much more development money would probably be spent on deciding
the spacing of the pushers. ;-)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Nope. Go to the Fossil page and hit "zoom photo" and you'll be able to see
the segments of the digits. They're the usual fixed segments, of a numeric
display, just funny shaped to mimic handwritten script and maybe a few more
segments than usual. In a pixel mapped display you wouldn't see the segment
outlines but in a zoomed in view you'd see the "jaggies" on the curves,
which would ruin the sleek effect of the handwritten font. I'm pretty
confident that the "til" , "after" etc. icons are separate segments that
are mapped "on" or "off" as a single element.
The programming is much easier for this kind of display than for a pixel map
but you have to have the ability to make a custom LCD screen just for this
watch. Instead of driving hundreds or thousands of pixels, you just have to
drive a handful of segments. with predefined mappings for each of the
digits. Fossil has a lot of experience with custom screens - they have all
kinds of LCD watches that display Chinese characters , etc.
Solution #3
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
It's a little more complex than that. ;-) The display this watch is
using is most likely similar to what you'd find in an older cell phone.
IOW, it's a pixel oriented graphics display (like a PC uses) instead of
a custom LCD that can only display fixed patterns. I'm reasonably sure
that by now these little displays can be had in bulk for around $1 each.
Certainly for a cost that would rival that of a traditional dial and
hands.
I did something like this, on a larger scale, using a 4" x 6" graphical
LCD display and an 8052 type microcontroller to keep time and drive the
display. I used the windos paint program to create bitmap images of the
numbers I wanted to display; courtesy of an OCR font that I had
available. ;-) I then converted that to C #include file descriptions
for use by the clock software by using some other glommed together
program that "cut" the numbers out of the bitmap. Just another stupid
micro trick, but it looked pretty cool with the OCR characters.
Solution #4
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
Hello NG:
In case someone of you is interested in digital watch programming,
Timex sells their Timex Datalink watch that can be programmed by its
user.
The application is developed in your PC and its behaviour simulated on
a desktop interpreter. When the application is ready to be deployed, it
is "cross-compiled" and then installed into the watch via a USB
connector.
See the url:
Regards,
Sergio G.
Solution #5
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
To expand on what our saintly friend said,
in addition to the usual digits there are
there are 3 extra segments of the lcd that light up "after", "half past" and
"til". Then it is just a few lines of code:
If minute counter is less than 30, display the minutes, the "after" segment
and the current hour.
If minutes = 30, display no minutes, display "half past" and display the
hour.
If minutes
This is around ten minutes worth of programming over and above what it would
take to make a "normal" LCD watch, plus you need a customs LCD screen. But
it ain't rocket science - in the mechanical era you had to be real clever to
pull off any kind of complication but in the electronic era it's just typing
at a keyboard, basically.
Solution #6
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
Like many quartz watches, they incorporate a microprocessor, so the
output is a SMOP (simple matter of programming).
St. John
Common sense is the most evenly distributed quantity in the world.
Everyone thinks he has enough.
-Descartes, 1637
Can you Help with these Watches problems?
Watches
I got the hair coloring
I got the hair coloring device... Answer This...
Watches
I have a Navy Seals
I have a Navy Seals 3100 series... Answer This...
Watches
will not turn over
will not turn over Answer This...
Watches
how do you add links
how do you add links to a... Answer This...
Watches
put new battery in but
put new battery in but can't... Answer This...
Repair Service
Find Watch Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
