Question about IBM ThinkPad T41 Notebook
Limited or no Wireless connection
I have an IBM Thinkpad T41. I have problem with my wireless network connection. It started suddenly couple of days ago. The wireless signal indication is strong, but the wireless connection status is: limited or no connection. When I use the repair button to repair the problem, I get the following message: "TCP/IP is not enabled for this connection. Cannot proceed."
When I tried to use the cable plug-in connection, it is all fine, no problem.
Thanks,
  • 1 more comment
  • yanbin_lu Feb 09, 2009
    How do I check the TCP/IP setting of the wireless adapter ? I can find network IP address.
    Thanks!
  • yanbin_lu Feb 10, 2009
    these are both selected. The wireless was working fine until about a week ago and just went suddenly.
    thanks,
  • yanbin_lu Feb 11, 2009
    It worked!!!!!!!
    Thank you somuch!!!! :) :)
  • IBM Master
  • 32,281 Answers
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Posted on Feb 09, 2009
  • Chris Hingee
    Chris Hingee Feb 10, 2009
    Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on Properties.
    Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
    If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
  • Chris Hingee
    It appears TCP/IP install/config is OK
    Before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
    Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on View Available Wireless Networks
    Do you see your wireless network (ie. your wireless router)?
    If so click on your wireless router and then click Connect.
    You can also click on Repair to try to reconnect to your wireless router.
    Let me know if it works.
How do you switch on wireless lan, also no sign of wireless network card . No wireless network connection icon in Network connections,i renew my windows i instal its driver but now there is no wireless...
You need to install the wireless card driver for the T41 ThinkPad.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Jun 10, 2011 | IBM ThinkPad T41 Notebook
I want to access the wireless
Make sure the wireless is turned on (there is a switch right under the screen), and you must know the password/name of the wireless network your attempting to connect to. Windows will have a wireless logo in the bottom right for you to click on and pick which of the available networks you want to connect to.
Mar 03, 2011 | IBM ThinkPad T41 Notebook
How do you turn on wireless on ibm t41 laptop pleses
IF.. you cant use a button/slider, and there is no FN key set to turn it on, control panel / network devices / right click on the wifi adapter and enable
Jul 18, 2010 | IBM ThinkPad T41 Notebook
IBMThinkPad T40 Wont connect to wireless networks.
Hello, if you see a yellow exclamation mark it means device drivers are not installed or are incorrect.
below is the link for IBM/Lenovo site that lists all the drivers for Thinkpad T40/T41. Go to that linkand scroll down to " Wireless Networking" and select the appropriate drivers: eg: Make sure it under T40 section, and not T41 since they are listed side by side.
since i am not sure which exact wireless card your T40 has i am posting this main link where it lists all options.
I would start with "ThinkPad 802.11bg wireless LAN Mini PCI adapter" if this doesn't work try next one in the list.
here is the link: http://www-307.ibm.com/pc/support/site.wss/MIGR-46258.html#wireless
I hope this helps, let me know if there is a problem.
Kind reagrds,
Amar Sondhi
Jan 22, 2010 | IBM ThinkPad T40 2373 Notebook
I have a ibm thinkpad which i formated and ilost the wireless access ican't connect to the internet wireless
check you have the driver installed by right hand clicking on my computer, select propertys then go to device manager. you will se everything hardware on your pc. check you have drivers instaled under wireless card. if you havent go to the IBM website and download them.
Dec 01, 2009 | IBM ThinkPad T41 Notebook
No wireless adapter found in XP on ThinkPad T41
Boot your laptop into windows. Go here to IBM Lenovo support and download the Cisco Wireless LAN Mini PCI adapter driver >>>>>>>
http://www-307.ibm.com/pc/support/site.wss/MIGR-42683.html
Once downloaded just execute the file as it is an .exe file, you will the wireless icon appear in the system tray (bottom right of the screen).
Regards.
Sep 15, 2009 | IBM ThinkPad T41 2373 Notebook
I am trying to connect my sons laptop to the wireless internet that I have .I have refreshed the wireless network connection and it says make sure the wireless switch on your computer is on. where is the...
What is the model of yuor laptop?
There will be wireless switch at the base of the laptop - turn it on. If still nok- - check system tray on the right hand side - you will find wireless switch utility there - enable wireless
Thanx
Sep 14, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Wireless adapter doesnt work at my new place
can you see your home wireless network in the avail wireless networks if so can you connect and enter the security key
Jul 20, 2009 | IBM ThinkPad T41 Notebook
I have ibm thinkpad t41 drivers problems !
Go to the IBM or Lenovo site and input your model number. You can access all the drivers from there.
Jun 08, 2009 | Computers & Internet
My Laptop stopped detecting wireless connections
Just double check that you have'nt accidently dissabled it by way of a shortcut key or switch on the front of the laptop in some cases. If not go to network connections, then locate your wireless network card and see if it says connected, if not right click and select connect. If still not responding, go to my computer>properties>hardware> device manager and go down the list to network adapters, click on it and see if there is an exclamation mark on it, if so there is a driver problem. If not right click on it, select uninstall, then restart your pc and let windows find it again and install drivers and try connecting to your network again.
Mar 16, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
632 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
