Question about Microsoft Computers & Internet
How to register .dll in locked PC?
.dll can be registered using regsvr32, it is required to have a unlocked PC.
But i have a case, where all the PC's are locked one.
So can anybody help me to register .dll file in locked PC?
  • 258 Answers
Press F8 every 5 secs during startup and select Safe mode
Logon as administrator and register the dll in there
Posted on Feb 09, 2009
When i am opening it, it is showing the program cannot start because loader.dll is missing from your computer try reinstalling it
Microsoft is constantly updating and improving Windows system files that could be associated with Loader.dll, sometimes resolving your DLL problems may be as simple as updating Windows with the latest Service Pack or other patch that Microsoft releases on an daily basis.
To help you install Windows update, please follow the steps given below:
- Steps used in (Windows XP, Vista, 7, 8, and 10).
- Click the Start button.
- Type 'Windows Update' into the search box and select it.
- The Windows Update dialog box will appear, if updates are available, click on 'Install Updates' button.
- After installing Windows Update, it is recommended to restart your computer once and then try using the computer.
If issue persists, you can use a built-in utility called 'Microsoft Register Server' (regsvr32.exe) to re-register your Loader.dll file.
In some cases your DLL file may not register properly and so you may get the error. To help you register Loder.dll file, please follow the steps given below:
- Type 'command' in the search box... DO NOT hit ENTER yet!
- While holding 'CTRL + Shift' on your keyboard, hit ENTER.
- You will be prompted with a permission dialog box and click Yes.
- Type the following command: regsvr32 /u Loader.dll and hit ENTER, this will UN-REGISTER your file.
- Now type the following command: regsvr32 /i Loader.dll and hit ENTER, this will RE-REGISTER your file.
- Close the command prompt window and restart the computer once again to check if the problem is fixed.
GuruAid.com
May 13, 2016 | Computers & Internet
Tip
How to fix update issues in windows ...
First of all, open an elevated command prompt, if u're using vista or win7 (right click on cmd and select run as administrator)
Then type in the following commands.. hit enter after each command...
net stop cryptsvc
net stop bits
net stop wuauserv
ren %systemroot%\system32\catroot2\Edb.log *.bak
ren %systemroot%\system32\catroot2 cat
exit
DO NOT RENAME OR DELETE ANYTHING PRESENT IN another folder named CATROOT, rename only the catroot2 folder
then click on start and browse to the folder
%systemroot%\softwaredistribution\
delete everything present in it
browse to the following folder
%systemroot%\system32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}
search for files tmp*.cat in it... delete them, DO NOT DELETE ANYTHING ELSE
now, we will unregister and re-register a few, 10 i believe, dlls
open an elevated command prompt once again,
and type in the following commands, or you can create a batch file ...
first we will unregister
regsvr32 /u softpub.dll
regsvr32 /u wintrust.dll
regsvr32 /u initpki.dll
regsvr32 /u dssenh.dll
regsvr32 /u rsaenh.dll
regsvr32 /u gpkcsp.dll
regsvr32 /u sccbase.dll
regsvr32 /u slbcsp.dll
regsvr32 /u mssip32.dll
regsvr32 /u cryptdlg.dll
exit
now restart the computer..
again open an elevated command prompt..
now we will re-register
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
regsvr32 mssip32.dll
regsvr32 cryptdlg.dll
exit
again restart
after restarting, in start search, type in, services.msc and hit enter
We need to check whether three services, namely,
Background Intelligent transfer Service (BITS),
Audomatic Update Service (wuauserv),
Cryptographic Services (cryptsvc);
are started and set to automatic or not, if not start them, and set the startup type as automatic...
Now perform the updates again, and the issue should be resolved...
on Dec 01, 2009 | Computers & Internet
How do i register on 2go?
You can use the Regsvr32 tool (Regsvr32.exe) to register and unregister object linking and embedding (OLE) controls such as dynamic-link library (DLL) or ActiveX Controls (OCX) files that are self-registerable. This may be necessary to troubleshoot some issues with Windows, Microsoft Internet Explorer, or other programs. It is also frequently used by program hacks.
1.) Copy the files you would like to register to [C:\WINDOWS\system32]
2.) Go to the command prompt Start --> Run --> cmd
3a.) To install/register the file type in: regsvr32 file.dll or regsvr32 file.ax
3b.) To uninstall the files type: regsvr32 -u file.dll or regsvr32 -u file.ax
4.) Some type of message should be displayed that says you successfully registered or unregistered the file
May 11, 2011 | Computers & Internet
Cannot access Email accounts from Internet Explorer. Get HTTPS: Error 12169. I can access Email accounts with Firefox. Also, uninstalled IE8 and went back to IE7 but that didn't help. Downloaded new...
Basically I found an article at Microsoft's site entitled "How to troubleshoot situations where you cannot complete MSN sign-up or connect to SSL secured (128-Bit) Web sites by using Internet Explorer in Windows XP"
To make a very long story short ... all you have to do is re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
To re-register these files, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type one of the following commands, and then click OK (copy and paste is your best friend):
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4. Click OK when you receive the message that says DllRegisterServer in FileName succeeded.
5. Repeat for each command line listed above
Mar 04, 2010 | Toshiba Satellite A35-S1592 Notebook
Dll missing file corruption data missing cant open application help
Search for the missing DLL file using search option in windows explorer. Copy the same to system32 folder and register the same using regsvr32 command.
e.g.: type regsvr32 XXXX.dll in Run command.
Revert back for more clarifications or assistance required.
Dec 12, 2009 | Caere Lone Wolf TimeWolf Plus 3.0 Full...
Windows error 646 cannot update windows norton live the same windows vista
The Error Code 646 can occur if the Windows Update Agent Wups2.dll file is registered incorrectly in the Operating System registry. So when you try to install a Windows Update, because the registry files that correspond to the Wups2.dll file are missing, the update installation fails.
Follow these steps to properly register the Windows Update files and resolve the issue:
1. Click the Start button, click All Programs, click Accessories, and then click Notepad.
2. In the Untitled - Notepad window, either copy and paste or manually type the following commands into the text field:
REGSVR32 WUPS2.DLL /S
REGSVR32 WUPS.DLL /S
REGSVR32 WUAUENG.DLL /S
REGSVR32 WUAPI.DLL /S
REGSVR32 WUCLTUX.DLL /S
REGSVR32 WUWEBV.DLL /S
REGSVR32 JSCRIPT.DLL /S
REGSVR32 MSXML3.DLL /S
3. On the menu bar, click File.
4. In the File menu, click Save As.
5. In the Save As window, in the File name field, type Register.bat.
6. In the Save as type field, click the down arrow and click to select All Files (*.*).
7. Click the Browse Folders button.
8. Browse to the Desktop folder, and then click the Save button.
9. In the Register.bat - Notepad window, click the X in the upper-right corner to close the window.
10. On the Desktop, right-click the Register.bat file, and then click "Run As Administrator".
NOTE: If prompted for an Administrator password or a User Account Control prompt is displayed, type the appropriate password, click Continue or click Yes.
11. Once the Register.bat file has run, click the Start button, click All Programs, then click Windows Update and try to install updates again.
12. NOTE: If the updates still fail to install properly, it may be necessary update the version of the Windows Update Agent software installed on the Computer.
Follow the steps in Microsoft KB Article ID 949104 to download and install the latest version of the Windows Update Agent software.
Good Luck!!!!!!!!!
Nov 15, 2009 | Microsoft Windows XP Professional
I have the same regsvr32 wintrust.dll error code 0x80070005 i cant log into my hotmail. i found in another forum that i should try running the following: regsvr32 softpub.dll regsvr32 wintrust.dll...
- Double click on the clock in the taskbar and make sure the system clock is set correctly.
- Disable Zone Alarm
- Register softpub.dll using the regsvr32.exe tool.Click Start, and then click Run.
- In the Open box, type regsvr32 softpub.dll and then click OK.
- Do the same for the following regsvr32 wintrust.dll, regsvr32 initpki.dll, regsvr32 MSXML3.dll.
- Restart Windows Live Messenger.
If you are still unable to fix Windows Live Messenger your computer might be infected, I recommend you Download registry cleaner to fix your errors and speed up your computer.
Aug 21, 2009 | Microsoft Windows Xp Home Edition English...
CANNOT update my windows and microsoft
check this link for more info
Thanks Good Luck
Appreciate to rate as "Fixya"
May 03, 2009 | Computers & Internet
Problem with accessing and sending mail from yahoo account
Re-register the following .dll files:
Softpub.dll
Wintrust.dll
Initpki.dll
Dssenh.dll
Rsaenh.dll
Gpkcsp.dll
Sccbase.dll
Slbcsp.dll
Cryptdlg.dll
1.
2.
In the Open box, type cmd , and then click OK.
3.
At the command prompt, type the following lines and press ENTER after each line:
regsvr32 dssenh.dll
regsvr32 rsaenh.dll
regsvr32 gpkcsp.dll
regsvr32 slbcsp.dll
4.
Click OK when you receive the message that DllRegisterServer in FileName succeeded.
5.
Type exit .
Mar 23, 2009 | Microsoft Windows Vista Business Edition...
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
