Question about Motorola Mobility HS820 Consumer Headset
Does not charge!!!
The light stays on during the charge period. I have connected it overnight but pressing the multi-function button, the light indicating that it has been charged DOES NOT come on.
  • 2 more comments
  • muzahirh Feb 09, 2009
    Thanks alot hari86... sounds like a battery problem to me as well.
  • Anonymous Feb 14, 2009
    how do you change the battery,the set is closed from all sides .please also guide which battery to use.
  • Anonymous Feb 18, 2009
    same problem
  • thebigdawq Mar 03, 2009
    My Motorola HS820, and I had 2, seems to have this recharging problem when the battery is completely drained. It was working fine, I put it down and forgot where I put it. The phone continued to pair with it. When I found it the battery was dead and now it won't recharge.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the best solution to this problem is that
replacing the old battery to a new one.It could
be your battery problem.It may have some fault
in it.so go for a new one.
try this out..
thank u..
rate me..
Posted on Feb 09, 2009
  • Hariharanath V Feb 09, 2009
    hi..ya that's the problem due to the poor
    battery.
    check it out..
    thanks..
How to connect to a Samsung tv
If you have Samsung wireless and need to pair them, then select sound, addition setting arrow down to Bluetooth ( may not be visible until you arrow down). Follow those instructions.
below this you will find how I set up old headphones.
I have a Samsung SU 4K, I also have an old wireless head phones. I did not want to buy expensive Bluetooth.
how did I make these work. First I purchased a digital optical convertor for $20. Since my headphones are 2 channel, I connected the base (red/white) to the convertor. Then I had to access Samsung menu audio. The Samsung TV has the manual built into TV terrible. Since I did not want the TV speakers off I had to find how to enable the output to headphones base. Select sound from menu , then additional settings , set audio format to PCM, also HDMI to PCM.
Jan 10, 2016 | Samsung Radio Communications
Can not connect my 9xxBackbeat bluetooth headphone to my laptop. My OS (Win 7 x32) recognize this device but then it says it can download the driver to run this device
In order to use this headset, your built-in Bluetooth in your PC needs to support the hands free profile, audio and A2DP profile. If it does, all you need to do is hold in the power button on the headset until you see the light on the headset flashing red/blue, red/blue. If it doesn't you'll need to load it onto your computer. Once the headset is flashing red/blue your computer should find it.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Backbeat 903 Bluetooth...
My headphones will turn on or charge.
Try performing a system reset: While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset. If it's still giving you problems, contact your retailer for warranty replacement (1 year warranty) or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
Mar 17, 2011 | Plantronics Backbeat 903 Bluetooth...
What is the pass key to my insignia bluetooth headset ns-bthdst
bluetooth Passkey
By default all bluetooth devices come with a 0000 passskey must earpieces won't allow you to change it unless is a very high tech device.
try that remember 0000 is the code.
if it works for you don't forget to rate me
thx
Apr 30, 2010 | Insignia Bluetooth Wireless Headphones...
How do i connect my backbeat 903 to my phone
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics web site)
Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Compatibility issues between Nokia BH 503 headset and Nokia N82 . The official Nokia India website states that of all the Nokia Bluetooth Enabled phones in the Indian market Nokia BH 503 is not compatible...
my nokia is having a headphones issue
when i attach headphone wid my nokia 5233 it also show a notification like headset connect bt do not give sound in ear phones
i hav try many compatible headphones but it is still not working
Apr 16, 2009 | Nokia Bluetooth Headset Headset
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility HS820 Consumer Headset Logo
289 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Pierre Curtis
Level 1 Expert
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
