Question about Cisco 2610XM Router
BUT IT IS NOY COMING THE PREVILAGE MODE(ROUER>)
THE PROBLEM IS ALREDY IS USED 2610 XM ROUTER I HAVE FORGETTEN THE PASSWORD OF THE ROUTER THATS WHY I DISCOVERY THE ROUTER (DONE THE PASSWORD BREAK)WHILE I AM DOING THAT AFTER RUNNING THE PROGRAME IT HAS COME rommon> AFTER THAT ASKED REGISTER NO I HAVE GIVEN NOT PERTICULER REGISTER NO OF THE ROUTER AND PRESS THE ENTER ALSO AFTER THAT ONE MEASSAGE HAS COME AND IT HAS TAKEN LITTLE TIME ALSO THAT TIME HE FIND OUT WRONG REGISTER NO HAS GIVEN AT I SWITCH OFF THE ROUTER ALSO AFTER SHORT WHILE AGO SWITCH ON THE ROUTER BUT IT IS NOT COMING THE PREVILAGE MODE(ROUTER>) WHAT CAN DO GIVE ME SOLUTION PLZ PLZ HELP ME
  • Doorguy27
    Doorguy27 May 11, 2010
    I sorry have a hard time under standing what your say... You lost the password to your router? Guess yes..
    Sergeant:
  • 286 Answers
Normally if you forget the password with cisco, boot the router in rommon mode and change the registry to 0x2142 and reboot the router and change the password and change back the registry to 0x2102.
did you tried this all ...can u explain more about the same
Posted on Feb 11, 2009
Forgetten my security code for my home broadband what do i do
Most routers come with the codes printed onto a sticker under the box, failing this and depending on what type of box you have you can hook your computer directly to the box using the ethernet cable, once done open up your internet explorer and in the address bar you can type in 192.168.1.1 (this is different for all boxes - this is for a netopia router) this will open the control panel for your router (mines is password protected with a default password "broadband") here you can find WLAN name and password.
But like I said it depends on what router you have, If you have no luck with the above please post up the name and model number of your router and your broadband provider
Nov 23, 2012 | Advent Computers & Internet
Can't find user and password
Reset your router and login with default factory settings.....Find the default username and password from user manual....
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Sep 18, 2012 | Allied Telesyn AT WA1104G Wireless Router...
I made a password and forgot it so now i cant play games.Whatdo ido
On the back or of your rouer near the AC adapter outlet there should be a very small reset button. Hold that down for about 10 seconds and it will reset your router to factory defaults. However, you will have to set up your network again.
Jul 10, 2011 | Computers & Internet
Trying to set password on my wifi cant get into settings admin noy working
Hi weiser691,
You can reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin.
Thanks for using Fixya
Feb 06, 2011 | Linksys Wireless-G WRT54G Router
I called time warner so they can guide me to change my password. they told me it was the only way i can kick someone off the wireless network. and then they told me i was going to recieve an email. i never...
For you to access the router settings pageof your SMC Router make sure that the rouer is connected to the computer using an ethernet cable so that the computer will be able to comunicate with the router. Then open a browser type 192.168.2.1 on the address bar. There will be no username and the default password is blank. Then you can now change/check the wireless setting page and change it with your desired settings.
Thanks for using Fixya.
Jan 27, 2011 | SMC (SMC7004AWBR) Router
Hi,I'm trying to access the configuration page of my D-Link DVG-G1402S by typing http://192.168.15.1 into internet explorer however but nothing happens. It doesn't prompt a username and password, just says...
For you to access the router settings page make sure that the rouer is connected to the computer using an ethernet cable so that the computer will be able to comunicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Then you can now change/check the wireless setting page and change it with your desired settings.
Jan 27, 2011 | D-Link Computers & Internet
How to have connections in my other pc if im using router , but if i direct the cable to the modem theres a connection?
One Ethernet cable goes from the WAN port on the router to the cable-modem (or DSL-modem).
Another Ethernet cable goes from one of the LAN ports on the rouer to your first PC.
Another Ethernet cable goes from one of the LAN ports on the rouer to your second PC.
Jul 27, 2010 | D-Link Computers & Internet
Reconfiguring rouer
If you have the setup CD you can just run it to your computer and let it reconfigure the router for you, but if you don't have the setup CD you need to manually configure the router by accessing its IP address using the computer that is wired directly to the router....
Nov 05, 2008 | NetGear WGR614 Wireless Router
Lost password
there is a restore button on the back of the router. it needs to be pressed with something like a paper clip hold it down for a few seconds and it should reset the router to the state it was in when it was new
Oct 14, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Open Questions:
2611XM Inbound NAT/Port-forwarding/Service Distribution Problems My NAT port-forwarding is working on some servers but not all servers. Keep getting (111) Connection refused when trying to access a number of the servers from outside. Searched and searched..tested...re entered them..have not been able to figure out. Thanks, Greg interface FastEthernet0/0 description ***Outbound interface connected to ISP*** ip address xxx.xxx.xxx.xxx 255.255.255.248 ip nat outside ! interface FastEthernet0/1 description ***Inbound interface connected to 2924 Core Switch-port 1*** ip address 192.168.15.1 255.255.255.0 ip nat inside THESE TWO WORK ip nat pool xxx_SAP 192.168.5.2 192.168.5.2 prefix-length 30 type rotary ip nat pool xxx_webserver 192.168.5.130 192.168.5.130 prefix-length 30 type rotary ! ip nat inside destination list 101 pool xxx_webserver ip nat inside destination list 102 pool xxx_SAP ! access-list 10 permit 192.168.0.0 0.0.255.255 access-list 101 permit tcp any host xxx.xxx.xxx.xxx eq www access-list 102 permit tcp any host xxx.xxx.xxx.xxx eq 3299 access-list 102 permit udp any host xxx.xxx.xxx.xxx eq 3299 THIS IS ONE OF THE ONES THAT DOESN'T WORK ip nat pool xxx_RDP 192.168.5.11 192.168.5.11 prefix-length 30 type rotary ip nat inside destination list 115 pool xxx_RDP access-list 115 permit tcp any host xxx.xxx.xxx.xxx eq 8089 access-list 115 permit udp any host xxx.xxx.xxx.xxx eq 8089 xxx_distribution_1#sh ip nat statTotal active translations: 1504 (0 static, 1504 dynamic; 1504 extended)Outside interfaces: FastEthernet0/0Inside interfaces: FastEthernet0/1, FastEthernet0/1.5, FastEthernet0/1.10, FastEthernet0/1.15 FastEthernet0/1.20, FastEthernet0/1.25, FastEthernet0/1.30 FastEthernet0/1.35, FastEthernet0/1.40Hits: 4130866 Misses: 93029CEF Translated packets: 4158864, CEF Punted packets: 110268Expired translations: 109237 Dynamic mappings: -- Inside Source [Id: 1] access-list 10 interface FastEthernet0/0 refcount 1469 -- Inside Destination [Id: 2] access-list 101 pool xxx_webserver refcount 22 pool xxx_webserver: netmask 255.255.255.252 start 192.168.5.130 end 192.168.5.130 type rotary, total addresses 1, allocated 22 (2200%), misses 0 [Id: 3] access-list 102 pool xxx_SAP refcount 13 pool xxx_SAP: netmask 255.255.255.252 start 192.168.5.2 end 192.168.5.2 type rotary, total addresses 1, allocated 13 (1300%), misses 0 [Id: 14] access-list 115 pool xxx_RDP refcount 0 pool xxx_RDP: netmask 255.255.255.252 start 192.168.5.11 end 192.168.5.11 type rotary, total addresses 1, allocated 0 (0%), misses 30
Feb 26, 2017 | Cisco 2610XM Router
Cisco 2610XM Router Logo
122 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
