Question about Epson Stylus C88 InkJet Photo Printer
No print how do clean the heads to allow new ink through to printer?
  • 258 Answers
Try Control Panel --> Printers and Faxes
Right Click on the printer and select properties
Look for a Clean, Maintenance or Tools Tab
You should find Clean or Deep Clean
Also remove the cartridges and use a tissue to wipe the ink outlets in case they have dried up
Posted on Feb 09, 2009
A printer,s ink pad is at the end of its service life
This means the waste ink collection sponge is full. This counter can be reset but it is strongly recommended to replace the ink pad as you will end up with a large amount of ink spilt on your desk if you continue to use the printer after the pads lifespan. It can be quite a large job to change depending on the model. If the printer is not an expensive model it may be more cost effective and less messy to simply replace it with a similar model.
Jan 14, 2017 | The Office Equipment & Supplies
5C00 Error Code as well as yellow and green alternating lights
To fix this error is much easier than it looks. Unplug the printer power. Move the ink cartridge cradle to the left. Over to the right you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now.
Jan 14, 2017 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
