Question about TallyGenicom 2348 24WIRE 480CPS Draft 136 Col Serial/parallel Matrix Printer
PRINTER DRIVER I HAVE A TELLYGENICOM 2348 SERIAL PRINTER. BUT NOT WORK. I WANT TO RE INSTALL THE DRIVER. BUT I HAVE NO INSTALLATION CD.
    Novelist:
  • 169 Answers
Visit the manufacturers web site. TallyGenicom have been taken over by Dascom, the web site is;
www.dascom.com
The drivers for the 2248 are on the follwoing URL;
http://en.dascom.firma.cc/index.php?option=com_content&view=article&id=253:2348&catid=8:serial-matrix-printer-drivers&Itemid=19
Posted on Sep 21, 2009
    Scholar:
  • 127 Answers
Try here:
http://tinyurl.com/cc736c
let us know, please rate. thanks.
Posted on Feb 09, 2009
2348 manuals
try to reset printer to factory default. dowload the seagullscientific drivers and reset from there, much easier. hope it helps, Paulo.
Mar 27, 2014 | Zebra Office Equipment & Supplies
Please help me install my printer HP Deskjet F4280
dear
you can go direct to hp accessories product trough google and you put ur product serial number and u can install it from there
Nov 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Dymo Labelwriter 450 Turbo won't print on Windows XP Pro system. Installed drivers & software from CD provided (Ver 8.0) Looks like it installed cleanly, but noticed that the printer didn't acknowledge...
Uninstall the driver, remove any trace of the install from the system (as much as is possible). Whent his gets messed up it's really hard to get working on that machine again under XP. Aquire the printer through add printer and detect not the software on the CD, install the driver using the inf file on the Cd. Now reinstall the printer software using USB or serial as an option, when prompted select custom install and no driver. If you have it setup on another machine this also works, but acquire the printer through network neighborhood instead of using add/remove programs.
Apr 06, 2010 | Dymo LabelWriter Thermal Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
Laser Printer Won't Work
Depending on what Operating System (OS) you are using, you need to install the driver usually in a CD that came with the printer. If you have no access to the installer CD, you can download the appropriate driver and install in your computer. Drivers are available here. After downloading, double click on the file that youo downloaded and follow on screen instruction.Should you have a need for the user’s manual, it is available on the Samsung site in pdf format.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 06, 2007 | Samsung ML 1210 Laser Printer
Model 4476-k02 serial # 22340443041
My Lxmark priter model is 4476-K02 and S.No. is 23385587803 2003/09. I Cant Use It.Because I hav'nt CD to Install It.
Nov 04, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
TallyGenicom 2348 24WIRE 480CPS Draft 136 Col Serial/parallel Matrix Printer Logo
322 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
