Question about Garmin Foretrex 101 GPS Receiver
Water inside Garmin, so no display.
How can I dismantle to dry it out?
This was recommended by Coopers4508 under the Forerunner 201 thread, and it worked equally well for my Foretrex 101.
As Coops said:
I know it sounds crazy, but worked without damage. Placed the forerunner in a table vice (long end to end) and gently applied pressure, opened right up.
It worked perfect for me - just be sure to compress slowly and listen for the separation of the centre seam. A very tidy solution.
Posted on May 01, 2009
If water gets inside the screen
Not alot, Unless you dismantle carefully and and slowly dry out. This needs someone who has experience to do this.
Most times the screen will need to be replaced. Very expensive.
Aug 30, 2012 | Dell Computers & Internet
Display has water tracks and is almost illegible
Best solution to this would be to replace the screen, unless drying and cleaning the display doesn't solve the problem.
Jul 13, 2008 | Garmin GPS
I dropped my E63 in the toilet, took it out straight away and tried to turn it on ( apparently doing that short circuits the battery and it dies) I had a blow dryer on the phone and battery for about 15...
Well this is the issue i'm trying to explain to some expert who believes that RICE is NOT TOTALLY EFFECTIVE.as a technician for several years.i never EVER heard that this solution totally accurate.
We are not talking about the phone must be dry inside,we are talking about It must be clean & dry inside,obviously that is different.
If you let the the water runs dry on your phone,rust or corrosion will be the result after.some parts would be damage if this rust EAT the metal parts usually PIN GRID IC as well as ball grid that connects into the PCB or mainboard,dis advantages are,some functions occurs such as keypad,display.tones etc.,mobile parts such as IC's is different from an appliances IC's,it is more functional as well as very sensitive.
If you can dismantle the phone and clean it as well (dry it of course),a big change to make the phone all functions work well because,no parts will be corroded or damage.
Take a look at this amateur video,this will guide you to dismantle your phone instead of explain it literally.
WATCH THIS
All you have to do is provide the following.
* a rust solution (such as WD-40) or a lacquer thinner * a cotton and a cloth * hair blower * a toothbrush
* upon dismantling the phone,apply the wet or corroded parts which is affected by water with a rust solution,gently brush the area,rub it it after with a cotton and wipe it with a clan and dry cloth,reheat the area with a hair blower in low level.now assemble the phone and test.
Well if there is some malfunction keys and encounter program abnormalities,you need to bring the phone to service center for a complete diagnosis and troubleshooting.
Aug 01, 2011 | Nokia E63 Cell Phone
The htcp3450 fell inside water, and i picked it out nd dry it with blower, then i put it ON then the screen is not displaying very well
It is better if you dismantle the phone and clean the LCD parts and area as well,might some corrosion/water stick to it,or clean the entire main board to ensure that no more wet area that may result to shot circuit.
Take a look at this video guide so it can help you dismantling your phone properly.
(just copy and paste the link on the address bar).
http://www.youtube.com/watch?v=E7n5Bk00Fxk
* You can use the following tools
use t5 or t6 precision screw, a rust remover or lacquer thinner, a toothbrush and a hair blower.
Good luck...
Jul 24, 2011 | HTC Touch P3450 Smartphone
Drop in water
Hi , The first thing you have to do is to dismantle ur mobile . Dry it for 2-3 day . When ur sure that it's totally dry then turn on . If it turns on , then well and good . If it doesn't , u can claim warranty (i believe u are in warranty period ) . Keep ur fingers crossed when u give ur mobile for service because there is a small sticker like thing stuck to the inside of the mobile to check if the mobile is damaged because of water . when the sticker comes in contact with the water , it's color changes (Or a similar mechanism is used to check) . Hope it's fine lets see . write back to me about ur proceedings If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Note : Don't ever try to turn on ur mobile and also don't put it for charge when it's wet .
Nov 21, 2010 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
What to do if your player falls in water
Once player falls into water, try to access the battery and remove it.
Loose the player with a screw driver and dismantle the components inside. Use heat or bulb to dry the component.
After heating, allow it to cool before you couple it back and leave it for a while before you put it back on. Make sure there is no trace of water after drying. The reason for drying is to make sure there is no water on the panel. And it is advice able to dry immediately so that the panel would not get rust.
You don't need to dry the battery with heat, you can just clean it with a dry cloth.
Best wishes.
Dec 28, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Camera got water inside. Tried drying out for a
Google the words...disassemble a digital camera. Even so, keep in mind water is disastrous to a digital camera.
Nov 09, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
I dropped my phone in tea, the phone still works but you cannot see anything on the display screen. Is there something I can do to fix it. Sony Ericsson Walkman W350a.
Short answer: No. Long answer: Your phone has water damage. Warranty is void if your phone has water damage. Since you KNOW you've dropped it in tea, you should consider it a lost cause and move on. For others - if you do something similar (dropped in water): Immediately turn it off. Take the battery out, then proceed to completely dismantle the whole phone. I have in the past used kleenex paper to tuck into places I can't dismantle, to get the water out, but they usually say to dismantle it, then let it completely air dry. It may take a week. If it, after it's completely dry, still works, then maybe you got lucky, and maybe it'll start acting up in a while, problem by problem as the electronics corrode inside the phone. I have heard of phones surviving water damage with only minor problems, but it's rare.
Jun 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Moisture in Navman Fish 4100
Yes, you can. In fact, you can actually clean the circuit board with DISTILLED water and then dry it with a hair dryer or leave it in hot sunlight. (No guarantee that the unit is still functional.)
Mar 29, 2009 | Boating
Water spots inside lenses
On the whole, I'd advise against dismantling binoculars yourself. Unlike most other optical devices, alignement is really important because you need to feed the same image into both eyes. If you're going to end up paying someone to realign the instrument, you might as well get them to do the cleaning at the same time. A.
Apr 20, 2007 | Bushnell Powerview 13-7016 (7-15x35)...
Garmin Foretrex 101 GPS Receiver Logo
608 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
