Question about Nokia 5310 Cellular Phone
Passcode on my phone
My phone is nokia 5310 when i try to connect with my blue tooth device it asks me a passcode. I cant figure it out.
  • 15 Answers
Most passcodes are 0000 but try your bluetooth's manufacture web site and they may have the instructions.
Posted on Feb 09, 2009
My bluetooth device is off but its on
First you need to check that the blue-tooth device is hidden or shown.This setting can be changed from the blue-tooth setting <device status>.But the easiest way is to Restore the phone setting by using the short code *#7780#.Good lick
Oct 10, 2011 | Nokia 5310 Cellular Phone
My nokia c7 not connecting to HP pavilion thru bluetooth
Make sure that the blue-tooth is active on the PC and the phone. Now search for devices and when it detects , confirm the passcode and accept the device so as to allow the transfer of files.
Open blue-tooth settings in phone from settings and in PC from blue-tooth manager.
Apr 08, 2011 | HP Computers & Internet
My nokia 3230 was unable to perform bluetooth operation
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Nov 25, 2010 | Nokia 3230
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Hi, my problem is with my nokia bh-214 headset.. when i try to connect it asks for a passcode.. i didnt get on with the unit and have tried the recomended codes like 0000, 1111, 9999, 1234, none of...
when you are pairing the head set and phone make sure the blue light is flashing on the head set witch the blue tooth put the blue tooth on the phone when asked put 0000 they should pair
the head set has to be charged to us it
Sep 07, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Unable to paired with my Nokia 5800, previously used with SE K800. help!
dISCONNECT THE DEVICE FROM SE K800 (Switching off Blue tooth in SE K800). It it is kept on the Blue tooth dwice connects automatically to the mobile phone,
Reset the Blue tooth device pressing for a little long duration till the On/Off indicator light glows permanently.
Then try to connect to the new Phone (Nokia 5800) using the passcode "0000" or the other which will be given in the Users manualy booklet.
MUTHUPETCHI V, MADURAI - muthupetchi008@gmail.com
May 29, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
6630bluetooth prolem
FIRST OF ALL RESTART YOUR MOBILE PHONE. THEN TURN ON YOUR BLUETOOTH CONNECTION ON YOUR PHONE. ALSO SET YOUR PHONE VISIBILITY ON FROM YOUR MOBILE BLUETOOTH MENU.
THEN TURN OFF YOUR BLUETOOTH DEVICE. NOW PRESS AND HOLD THE POWER BUTTON ON YOUR BLUETOOTH DEVICE. WHEN THE LIGHT BLINKS YOUR BLUETOOTH DEVICE IS DISCOVERABLE FOR YOUR PHONE.
NOW SEARCH FOR A BLUETOOTH DEVICE FROM YOUR MOBILE'S BLUETOOTH MENU. YOUR DEVICE WILL BE DISCOVERED BY YOUR MOBILE. NOW ADD THE BLUDTOOTH DEVICE TO YOUR MOBILE THE PASSCODE SHALL BE 0000 OR 1111.
NOW YOU CAN USE YOUR BLUETOOTH. IF STILL UNBALE TO EXCESS PLS. ASK US.
PLS. RATE MY SOLUTION.
NICE DAY
REGARDS
KETAN PATEL.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Mar 14, 2008 | Motorola Mobility RAZR V3
Motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Oct 31, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 5310 Cellular Phone Logo
99 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
