Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
HL-P5O63W : Rear Lamp Cover Error!
I have a HL-P5063W also. It is from August 2004 and few months ago the image started dimming. So i got a replacement lamp and put it in. But then the lamp fan became very nosiy every time i would turn the tV on. It would make a very loud sound like it is winding up and down. I tried putting the old lamp back in and got the same problem. SO i figured it is a fan issue and put the new lamp back in. But now the Lamp and Standby lights are flashing indicating a lamp cover issue. The lamp cover is on the back and properly secured.
What could be cuasing the tv not to start up or not to sense the cover is on?
  • Anonymous Feb 10, 2009
    Where is the rear lamp switch? I know when i was putting the door on it sounded like something plastic snapping and/or falling. Im afraid maybe that is what broke? Does anyone know where it is or have a picture so ic an check...and if so any way i can fix this?
    If it is the color wheel what is my solution? The sound is defientely coming form where the fan housing is located...but who knows what else is over there.
    Thanks for the response. If it is the color wheel how do i solve the problem? The sound was coming from the area where the fan and fan housing is. Is the color wheel in the same place (im assuming so since the lamp faces towards that area)?
    As far as the rear panel goes. Can you tell me where the lamp switch is located (and/or provide me a picture). When i was reinstalling the door after putting the new lamp back on I did hear what sounded like plastic snapping and falling. I quickly opened it up again and checked but failed to find any broken plastic or determine what was broken. But after that i started getting the rear panel error. Maybe if i can find the switch i can permanently fix it up so that way the tV can turn on again if that is the problem.
  • 42 Answers
That my be the color wheel you are hearing
They will make a huge whining noise
The lamp door also had issues the lamp switch must be in the up position when you put the door back on
Posted on Feb 10, 2009
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
Apr 02, 2012 | Samsung Televison & Video
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I just replaced the lamp on my samsung HL-P5063W (DLP TV) the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise. should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My picture won't show after replacing the lamp
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Jul 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
181 people viewed this question
Jerry Greenberg
Jerry Greenberg
