Question about Hilti 3431126 SF 144-A CPC Drill/Driver
Gear grease for hilti drill/driver
I have used hilti SF 150-A. I want to clean gears and put new gear grease. At the hilti store I went to, they weren't able to tell me what exatly should I use so that would be my question to you, or is it possible to get gear grease that hilti uses?
    Sniper:
  • 61 Answers
The genuine hilti grease isnt that easy to get. but I have used a stadard lithium grease in the past without any problems.
Posted on Feb 24, 2010
Where can buy hilti sf 144 switch
GO TO http://www.us.hilti.com/holus/page/module/product/prca_catnavigation.jsf?nodeId=-71302
Mar 14, 2012 | Hilti 3431126 SF 144-A CPC Drill/Driver
I own a Hilti SF 150-A 15.6 volt cordless drill ( non hammer type ). I need a trigger assembly for it. Where can I order one?
As i know Hilti has a free of charge repair or replacement of defective parts; Hilti tools are covered by a lifetime manufacturer's warranty against material or manufacturing.Call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Hilti Cordless Drill Driver SF 151A 20Ah...
From where can i buy a switch for my hilti sf 121a
Under Hilti, the SF 121 is the battey part number. I would need the tool's part number to know which switch you need. On the bad side, I haven't been able to find a secondary market for Hilti parts, you usually have to buy from them. Hilti's number is (866) 445-8827 if you would like to call them and order the part.
Aug 23, 2010 | Hilti 285359 SF 121-A 2.0 NICD Cordless...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti DD130 Core Drill gearbox Lubrication
Hi
220ml of synthetic 68 gear oil.
Hope this helps
Nov 28, 2009 | Hilti 3431126 SF 144-A CPC Drill/Driver
Grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Oct 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a Hilti Hammer Drill model TE5
Tip - Get a can of PB Blaster from your local hardware store and spray a little into the bit holder. Use a long screwdriver and push down the piston. Hit the switch for a minute, letting it work in. Put a bit in and get to drilling. Unless its old, then the o-rings may just be worn out. That stuff does recondition o-rings too. Lemme know. Please rate me
Oct 25, 2008 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a Hilti Hammer Drill model TE5 and I need know grease to use in it
the grease is called turmoil grease and is somewhat expensive. This also requires just about complete disassembly of the tool and smoe parts replacement.
Hilti 3431126 SF 144-A CPC Drill/Driver Logo
1,273 people viewed this question
Top Hilti Drills Experts
John Trevino
Phil Rivera
Are you a Hilti Drill Expert? Answer questions, earn points and help others
