Please can you give me the timing specs for a vw fox 1.8 89 model
thanks
brad
Tune-up Specifications
Air/Fuel Ratio
0.7%
Air/Fuel Ratio-Limits[1]
0.3 - 1.1%
Timing[2]
6°+/- 1°BTDC
Timing Advance[3]
30°+/- 3°BTDC
Idle RPM[4]
800 +/- 50
[1]
Check CO with the oxygen sensor connected.
[2]
AT 2300 RPM, and coolant temperature sensor disconnected.
[3]
Normal operating temperature, with coolant temp. sensor connected, at 2300 RPM. Add initial timing.
[4]
A/C off.
Timing mark is on flywheel, access hole is on top of bellhousing. Remove access plug with 27mm wrench if necessary
Firing Order is > 1342 Clockwise Rotation & #1 Plug Wire is at 2 Oclock on Distribitor Cap
Align the mark (can be a dot or notch) on the intermediate shaft sprocket with the notch in the crank pulley. Align the mark (can be a dot or notch) on the "Back" of camshaft sprocket with the top edge of the valve cover gasket. Be sure all the timing marks are properly aligned.
For further information refer to Timing Belt : Service and Repair
NOTE :
The 8 valve engine requires a special wrench, Volkswagen No. US4493 or equivalent, to adjust the camshaft drive belt tensioner. Whenever the drive belt is removed and refitted, the camshaft and intermediate shaft timing MUST be adjusted. The drive belt can be replaced without removing the belt sprockets.
NOTE :
On high mileage engines, failure of the tensioner bearing is a possibility. Consider replacing the bearing when replacing the timing belt.
NOTE:
Very slight movement of sprockets and marks can be expected as belt tension is adjusted. Slight movement is OK. The smallest possible increment of adjustment is one whole tooth of the belt or sprocket.
Please Dont Forget To RATE ME !
