Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washer won't start
Our washing machine works perfectly once you can get it to start. Thats the problem - when you press the start button, it beeps but nothing happens.. sometimes if you open and close the lid a few times it will work... any ideas how to fix this?
  • Anonymous Feb 19, 2009
    I brought the GW711 from a second hand store, tells me he had put a new pump in it, worked good one the first load. I turned it all on ok, & set the delay start for 9 hours, I got home from work & the machine had no lights on, the wash hadn't been done & now I can't even get it to turn on, totally dead!!!! Not happy.
  • tom8911 Mar 05, 2009
    Ours is F&P Excellence GW609 (6.5 kg). When you press the start button it just won't fill water. Had same problems a few months back and managed to get it to work by touching the nozzles that dispense water in the bowl. Today, it just won't do anything.
fanny
  • 146 Answers
SOURCE: Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Posted on Nov 04, 2007
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
  • 343 Answers
SOURCE: Fisher and paykel GW611 excellence top loader wont
Check Out Of Balance switch This will prevent spinning and programme from advancing
Posted on Apr 18, 2010
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
Fisher and paykel won't let water in but just sensing water level non-stop
Any switch the same size will work there fine,
It must have the three pins,com, nc, no on the switch.
May 08, 2012 | Fisher and Paykel Fisher & Paykel Washer
My Fisher Paykel top load aqua smart washer won't
it wont spin if there is water remaining in it,check pump for restrictions or anything jamming it if good replace pump
Apr 27, 2012 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel GW609AU washing machine
keep it simple, make sure water is on to both hot and cold hoses. Trip switches for door (and sometimes soap draws) can prevent machine working. Try asking a few logical questions. Has the machine been moved recently? If its out of level this could be a problem. Check solenoids are working (these are electrical taps at the back of machine which hoses hock up to), to do this try both hot and cold settings. Even try changing water level settings to further attempt to deduct were problem might lie. hope this helps and let us know how u go
Aug 08, 2011 | Fisher and Paykel Washing Machines
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
470 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
