Question about APC (SUA3000I) UPS System
Failing APC 3000s
We have purchased 8 of these units, and have installed 4 of them so far. After a few days, the first unit installed began to fail. Within the last week we have had the 2nd and 3rd units fail. The batteries test fine and appear to be fully charged, however the control unit begins to flash a red indicator and then turns off. We have swapped 2nd and 3rd units with the remaining systems and I received a note on Friday that one of those has begun to trip out and turn off.
I'll get to take a closer look at these units tomorrow, but anyone else having these problems with these units.
It's not looking good for this model from our perspective.
    New Friend:
  • 37 Answers
Well it could be the driver of the relay havin the problem or the mosfet is faulty.. that will be the hardware problem hmmm i askin hav you install any software or smnp card?? and how high is your input current?? and how much load you connected to ups.. i suspect the UPS u purchase it frm the USA and the current that opperated is 208ac it could be also the problem if the ups havin setup to 240ac..
Posted on Mar 24, 2009
    Problem Solver:
  • 21 Answers
  • old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Posted on Feb 10, 2009
Battert tab broke when attempting to remove (replace) batteries. Cannot get old batteries out of Smart UPS1000. Front-most battery appears to have swelled.
You'll need to remove the cover and battery cage from the unit. I've run into this before, just take your time and be careful there are likely some sharp edges inside.
When the batteries overheat and swell, they press against the metal in the unit and get wedged in.
I found a related post about APC 3000s.
Dec 09, 2012 | APC Smart-UPS 1000VA UPS System
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
I connected 8, 100Ah battery with APC 2.2KVA inverter, now it doesnt give correct battery indication and keep producing beeping noise, whats the problem?
Continuous Beeping (theamber On Battery LED will be illuminated)
This alarm indicates that the UPS has reached aLow Battery condition and will soon shutdown. The UPS can only operate onbattery for a limited amount of time. In order to protect the unit's batteriesfrom discharging too much, the UPS will shutdown and turn off its output. Towarn you that the unit will soon shutdown, the UPS will sound this alarm 2minutes before actual shutdown. With optional Powerchute Plus software, 2minutes can be changed to 5, 7, or 10 minutes to give you more of a warning ofimpending shutdown. If you hear this tone, you should immediately gracefullyshutdown your operating system to prevent data loss or corruption.
Note:This graceful shutdown will occur automatically if Powerchute PLUS software isbeing used.
Constant, Solid Tone (the red Overload LEDwill be illuminated)
This alarm indicates that the UPS has detectedan Overload condition. If this alarm is sounded, try removing non-essentialequipment. The alarm will remain until the load is reduced. To determine ifyour UPS is capable of handling the equipment you want to protect, visit APC'sSizing Guide at www.apcc.com/sizing.
Continuous Beeps for One Minute; RepeatedEvery 5 Hours (Replace Battery LED will be illuminated)
This alarm indicates that the UPS has failed itsSelf-Test of the battery. The unit will continue to sound this alarm until theunit passes the test. Try to let the unit charge for a few hours and thenperform another Self-Test (Press and hold the on/off button until the second'chirp', then release). If it fails and the unit is still in-warranty (twoyears from date of purchase), then contact APC. If the unit fails and its outof warranty, then order a replacement battey cartridge through your reseller,distributor, or from APC's web site.
Apr 21, 2011 | APC Computers & Internet
I have the APC 1250 Backup and the replace battery light is flashing. Is there a battery in the unit or do I have to replace the enitre unit?
There is a battery in the unit, which most likely needs to be replaced. You can find replacement batteries at a variety of retailers. To get an idea of price, search here. For documentation on your product, you can consult the guides listed here.
Mar 03, 2011 | Office Equipment & Supplies
What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Jun 20, 2009 | APC VS 500VA (VS500VA) UPS System
Xdm46cc
I bet your unit is about 4 years old...
I have installed 4 of these systems 4 years ago and each is failing at about the 4 year mark (3 so far).
The flashing volume lights are a communication error, meaning the keypads are not communicating with the controller. If all of the keypads are doing the same thing and your have checked your cables then the problem is with the controller. I would unplug the unit for a few days and see if that helps.
It appears the units work consistently and reliably for about 4 years however in my case 75% have failed at the 4 year mark.
Fortunately I have a meter and oscilloscope and determined why they are failing. The main power supply unit that feed power to the 5VDC regulator is failing.
It is not clear whether M&S replacement units have addressed this problem or not. Therefore, to fix the problem for my customers, I added and additional small power supply (fits inside the case) and injected the signal on the input side of the 5VDC regulator. My solution hopefully will not expire after 4 years.
It appears to me from my small sample size that M&S may have a flaw in their original engineering and replacing it with the same will guarantee future failure.
I hope this helps others. :)
Oct 29, 2008 | M&S Systems Local Audio Input Module -...
Unit is switching to battery power for now reason.
Any UPS monitors the incoming AC level to determine if it is needed or not.  I think the APC unit doesn't know any more when it is needed; it's sick.
Sep 23, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
Oct 30, 2007 | APC Back-UPS ES 350 - UPS ( external ) -...
APC (SUA3000I) UPS System Logo
181 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
