Question about Element ELC-HS321 32 in. LCD TV
Element 32'' LCD TV, has picture but no sound
The cable works fine, but the s-video hookup for the game consoles has no sound. Anyone have any suggestions for this? The TV Model # is ELCHS321. Thanks
  • 1 more comment
  • glknuth Feb 09, 2009
    Thanks, my Mom must have messed with the wires while I was asleep. Ahh, the perils of working nights...
  • Anonymous Mar 15, 2014
    my element model ELCHS321 has sound but no pick unless u hold a flashlight to the screen then u can see the pick any ideas?
    President:
  • 1,077 Answers
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Posted on Feb 09, 2009
I need a owner manuel for my 32 inch hdtv so i know how to work it
Posted on Feb 25, 2009
SOURCE:
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
Wii to Philips LCD TV 32"" - sound but no video. Just bought a refurb. Philips LCD TV for our WII. The standard AV cable gave sound, no video. The warning message flashes up in the beginning...
Looks like the AV port in your Philips television is busted. It's the only factor if the Wii is able to function with other tv with the same cable. You can either purchase a new television/get the one you have fixed (these will cost money) or you could just purchase an hdmi cable which doesn't use the same port so it could possibly work with your Philips television.
Jul 07, 2011 | Nintendo Wii Console
Get a picture but no sound
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Apr 26, 2010 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
My Wii is on and I can hear the sound, but the picture won't come up. My Playstation works fine and we tried all the hookups
This would probably be the cord that is bad or has a short or somthing as if your getting sound and not video you will need to replace this cord from the WII to the Tv it should work fine then, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 18, 2009 | Nintendo Wii Console
Ps3 is working ok, but wont displace on tv screen. i can hear the game playing away,but no picture on tv. tv working fine. anyone know what could be the problem
jus keep checking the cables in the back of the tv and if they are in correct it could jus be the video cable is being dodgy lol
May 04, 2009 | Sony Playstation 3 (PS3) Console
No sound or picture.boots up ok
The television shouldn't make a difference. Try changing out the Cable that goes from the xbox to the television. If still no picture then open the box up and see if you have any loose connections. If there are no loose connections then it sounds like that you have a bad video chip on the motherboard.
Mar 16, 2009 | Microsoft Xbox Console
I have sound but no picture.
Have you tried replacing the cable that connects the PS2 to your TV? Might be something wrong with the video portion of the connector.
Mar 04, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 hookup to lcd tv
If your sanyo has a video input (yellow) available, and audio inputs available (white and red) then you just need to connect them. Then you need to select the proper input on the TV set. These may be on the back, side, or front of the TV.
Good Luck, and let me know how it worked out!
Jan 01, 2008 | Sony PlayStation 2 Slimline Console
Element ELC-HS321 32 in. LCD TV Logo
2,571 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
